There is no possibility to set the smooth option in the previewer panel programmatically in the VC++ routines:
If you want to preview OpenGL graphs then you have to switch on the smooth option button on the left panel in the previewer, see the following image:
How can I switch on/off this button programmatically from VC++ 6.0, I don't see any possibility, not in the CPrinter class not anywhere else, to do this in the ActiveX wrapper classes for VC++ 6.0, could this be implemented in one of the next releases ??
Thx in advance,
Michael Kuelshammer
Germany
How to set the smooth option in previewer
Hi Michael,
you can by setting the AsBitmap property to try, i.e (VB code) :
Private Sub Command1_Click()
With TeePreviewer1
.Chart = Chart
.Options.AsBitmap = True
.ShowPreview
End With
Pep Jorge
http://support.steema.com
