Method to set starting Y value in Left Axes
toolbox
Post by toolbox » Fri Jun 22, 2012 8:41 pm
Is there a way to set the starting Y value where X/Y intersect? I have the need to show the lowest value from the Y Axis in the chart. I should note that this chart has both area and line within one chart. Also to note is that this is using the iOS Tchart library.
I have tried a couple different ways including:
Setting automatic to false and then specifying the left minimum and maximum values
areaLY.Chart.Axes.Left.Automatic = false;
areaLY.Chart.Axes.Left.Minimum = Math.Round(areaLY.Chart.Axes.Left.MinYValue);
lineTY.Chart.Axes.Left.Automatic = false;
lineTY.Chart.Axes.Left.Minimum = Math.Round(lineTY.Chart.Axes.Left.MinYValue);
areaLY.Chart.Axes.Left.Maximum = Math.Round(areaLY.Chart.Axes.Left.MaxYValue);
lineTY.Chart.Axes.Left.Maximum = Math.Round(lineTY.Chart.Axes.Left.MaxYValue);
The second method:
areaLY.Chart.Axes.Left.SetMinMax(Math.Round(areaLY.Chart.Axes.Left.MinYValue),areaLY.Chart.Axes.Left.MaxYValue);
lineTY.Chart.Axes.Left.SetMinMax(Math.Round(lineTY.Chart.Axes.Left.MinYValue),lineTY.Chart.Axes.Left.MaxYValue);
In the attached screen shot the lowest value is actually 932, so I want to show 900 where x/y intersect in the chart. Currently you'll see in the chart the starting value is 1000.
ios tchart.jpg (24.8 KiB) Viewed 3709 times
Re: Method to set starting Y value in Left Axes
Post by Sandra » Tue Jun 26, 2012 11:59 am
Hello Toolbox,
Can you tell us if next code help you to solve your problem:
        Steema.TeeChart.Styles.Line lineTY;
        Steema.TeeChart.Styles.Area areaLY;
            double max, min;
            areaLY = new Area(tChart1.Chart);
            lineTY = new Line(tChart1.Chart);
            areaLY.Color = Color.Green;
            areaLY.Transparency = 50;
            lineTY.Color = Color.Red;
            lineTY.LinePen.Width = 2;
            tChart1.Axes.Left.Grid.Visible = false;
            areaLY.AreaLines.Visible = false;
            Random rnd = new Random();
            for (int i = 0; i < 52; i++)
                areaLY.Add(i, rnd.Next(1500));
                lineTY.Add(i, rnd.Next(1500));
            max = Math.Max(areaLY.MaxYValue(), lineTY.MaxYValue());
            min = Math.Min(areaLY.MinYValue(), lineTY.MinYValue());
            tChart1.Axes.Left.SetMinMax(min, max);
Note, that my code is in Winforms and you need adapt it to TeeChart for iOs. Also, can help you to achieve as you want is change the Min/Max offset value,e.g change 0 to 1.
