Axis Break tool with datetime in X axis
BNF Tech Inc.
Post by BNF Tech Inc. » Mon Jun 18, 2012 6:52 am
I am trying to use Axis break tool with steema line chart. my x axis have datetime and y axis have value.
but every time I run my project tchart crashed. :(
            //InitializeChart.
            tChart1.Series.Clear();
            DataTable dt = new DataTable();
            dt.Columns.Add("YH01_CO_1MS-TT04A");
            dt.Columns.Add("DATETIME",typeof(DateTime));
            dt.Rows.Add(new object[] { "39,355,408", "06/01/2012" });
            dt.Rows.Add(new object[] { "87,831,335", "06/02/2012" });
            dt.Rows.Add(new object[] { "144,763,408", "06/03/2012" });
            dt.Rows.Add(new object[] { "144,662,737", "06/04/2012" });
            dt.Rows.Add(new object[] { "119,927,461", "06/05/2012" });
            dt.Rows.Add(new object[] { "91,398,604", "06/06/2012" });
            dt.Rows.Add(new object[] { "38,522,013", "06/07/2012" });
            dt.Rows.Add(new object[] { "34,226,876", "06/08/2012" });
            line1.XValues.DateTime = true;
            line1.DateTimeFormat = "MM/dd/yyyy";
            line1.Pointer.Visible = true;
            line1.Pointer.Style = Steema.TeeChart.Styles.PointerStyles.Hexagon;
            line1.Title = dt.Columns[0].Caption;
            line1.DataSource = dt;
            line1.LabelMember = "DATETIME";
            line1.YValues.DataMember = dt.Columns[0].Caption;
            line1.XValues.DataMember = "DATETIME";
            line1.Color = Color.Red;
            line1.CheckDataSource();
            //AxesBreaks.
            Steema.TeeChart.Tools.AxisBreaksTool axisbreak = new Steema.TeeChart.Tools.AxisBreaksTool(tChart1.Chart);
            Steema.TeeChart.Tools.AxisBreak axisBreak1 = new Steema.TeeChart.Tools.AxisBreak(axisbreak);
            //Steema.TeeChart.Tools.AxisBreak axisBreak2 = new Steema.TeeChart.Tools.AxisBreak(axisbreak);
            axisBreak1.StartValue = Convert.ToDateTime("06/05/2012").ToOADate();
            axisBreak1.EndValue = Convert.ToDateTime("06/07/2012").ToOADate();
            //axisBreak2.StartValue = DateTime.Today.AddDays(10).ToOADate();
            //axisBreak2.EndValue = DateTime.Today.AddDays(15).ToOADate();
            axisbreak.Axis = tChart1.Axes.Bottom;
            tChart1.Axes.Bottom.Labels.DateTimeFormat = "MM/dd/yyyy";
            axisbreak.GapSize = 20;
Environment Information
OS : Win 7 professional
.net version : 3.5
visual studio 2008
lang. : c#
can you please help me on this issue?
Namit Shah
Re: Axis Break tool with datetime in X axis
Post by Sandra » Mon Jun 18, 2012 12:20 pm
Hello Namit,
I suggest you take a look in this thread where there is an example as you do to use Tool Axis Breaks correctly.
BNF Tech Inc.
Post by BNF Tech Inc. » Mon Jun 18, 2012 12:46 pm
Hi Sandra,
first of all, thanks for your reply.
Basically I started my devlopement from that thread only.
Your code in that thread ,working fine.
I just replace candle series with line series and I take data from datatable instead of using fillsamplevalues() method.
but its not working :(
Can you please figureout what exactly cause of error tchart crashing?
Namit Shah
Post by Sandra » Tue Jun 19, 2012 4:20 pm
Hello Namit,
I haven't forgotten you. We are investigating why your problem occurs and we try to answer you asap.
BNF Tech Inc.
Post by BNF Tech Inc. » Wed Jun 20, 2012 1:55 pm
Hi Sandra,
I am stuck in this situation :(
I have deadline to complete it.
Can you please give me any workaround or solution of this problem as soon as possible?
Thanks!
Namit Shah
Post by Sandra » Mon Jun 25, 2012 3:15 pm
Hello Namit,
Sorry for the delay. Finally, I have found the problem and seems it must be caused for the assignation the "DATETIME" to DataLabelMamber and the order of you add values. To solve the problem I have removed the assignation and change the order of DateTime values and now your code works fine for me.
            //InitializeChart.
            DateTime DateNow = DateTime.Now;
            dt.Columns.Add("DATETIME", Type.GetType("System.DateTime"));
            dt.Columns.Add("YH01_CO_1MS-TT04A", Type.GetType("System.Double"));
            dt.Rows.Add(new object[] { "06/01/2012", "39,355,408" });
            dt.Rows.Add(new object[] { "06/02/2012", "87,831,335", });
            dt.Rows.Add(new object[] { "06/03/2012", "144,763,408" });
            dt.Rows.Add(new object[] { "06/04/2012", "144,662,737" });
            dt.Rows.Add(new object[] { "06/05/2012", "119,927,461", });
            dt.Rows.Add(new object[] { "06/06/2012", "91,398,604" });
            dt.Rows.Add(new object[] { "06/07/2012", "38,522,013" });
            dt.Rows.Add(new object[] { "06/08/2012", "34,226,876" });
            //Remove DataLabelMember.
            axisBreak1.StartValue = line1.XValues[3];
            axisBreak1.EndValue = line1.XValues[6];
            //axisBreak2.StartValue = DateTime.Today.AddDays(4).ToOADate();
            //axisBreak2.EndValue = DateTime.Today.AddDays(6).ToOADate();
            //tChart1.Axes.Bottom.Increment = Steema.TeeChart.Utils.GetDateTimeStep(DateTimeSteps.OneDay);
Can you tell us if previous code works as you want?
BNF Tech Inc.
Post by BNF Tech Inc. » Wed Jun 27, 2012 12:16 pm
Hi Sandra,
Yes your code working fine after some modification.
Thanks for your help. :)
Namit Shah
BNF Tech Inc.
Post by BNF Tech Inc. » Sat Aug 04, 2012 11:57 am
Hi Sandra,
I found strange new problem with your solution.
If I use tChart1.Axes.Bottom.Labels.DateTimeFormat = "HH:mm"...all the bottom labels are disappeared from chart.
To reproduce the problem ,please use below code.
            //InitializeChart.
            dt.Rows.Add(new object[] { "06/01/2012 14:00", "39,355,408" });
            dt.Rows.Add(new object[] { "06/01/2012 15:00", "87,831,335", });
            dt.Rows.Add(new object[] { "06/01/2012 16:00", "144,763,408" });
            dt.Rows.Add(new object[] { "06/01/2012 17:00", "144,662,737" });
            dt.Rows.Add(new object[] { "06/01/2012 18:00", "119,927,461", });
            dt.Rows.Add(new object[] { "06/01/2012 19:00", "91,398,604" });
            dt.Rows.Add(new object[] { "06/01/2012 20:00", "38,522,013" });
            dt.Rows.Add(new object[] { "06/01/2012 21:00", "34,226,876" });
            tChart1.Axes.Bottom.Labels.DateTimeFormat = "HH:mm";//"MM/dd/yyyy";
PLease see attached scrren shot of problem.
Can you please help me on this issue?
Namit Shah
Screen shot of Problem
Post by Sandra » Tue Aug 07, 2012 10:41 am
Hello Namit,
After doing many test, I have added your problem in the bug list report with number[TF02016292] to investigate the problem and try to fix it to upcoming versions of TeeChartFor.Net.
