I'm using the chart and using:
series.TreatNulls = Steema.TeeChart.Styles.TreatNullsStyle.DoNotPaint
I have attached an image of how the graph is painted.
My problem is that the lines go to 0 where the null value is instead of just having a missing segment.
Another problem is that when i use down-sampling the null values do not show.
- graph.png (35.1 KiB) Viewed 3834 times
Re: Steema.TeeChart.Styles.TreatNullsStyle
Hello MeirS,
Using last version and next code, your problem doesn't occur for me:
Can you tell us if you can reproduce your problem using previous code? On the other hand, can you tell us which version of TeechartFor.Net are you using?
Steema.TeeChart.Styles.FastLine fast1, fast2, fast3;
//tChart1
fast1 = new FastLine(tChart1.Chart);
fast2 = new FastLine(tChart1.Chart);
fast3 = new FastLine(tChart1.Chart);
fast1.XValues.DateTime = true;
fast2.XValues.DateTime = true;
fast3.XValues.DateTime = true;
fast1.FillSampleValues();
fast2.FillSampleValues();
fast3.FillSampleValues();
fast1.LinePen.Width = 2;
fast2.LinePen.Width = 2;
fast3.LinePen.Width = 2;
fast1.SetNull(15);
fast2.SetNull(15);
fast3.SetNull(15);
fast1.TreatNulls = TreatNullsStyle.DoNotPaint;
fast2.TreatNulls = TreatNullsStyle.DoNotPaint;
fast3.TreatNulls = TreatNullsStyle.DoNotPaint;
