URGENT::Latest 2012 build for CG2010 causes EEFACE
I installed the Mar 28 dnld and evrytime I run the exe I get an EEFACE -- this is an urgent matter as we are dead in water--we are using TEEChart in a very simple pie drawing in an Intraweb app...we previously had 2011 installed and it worked fine...also the pie chart does not fill properly on the left side -- it looks like two disks -- see attached pic
- pic.png (46.61 KiB) Viewed 3282 times
Re: URGENT::Latest 2012 build for CG2010 causes EEFACE
I'm not sure to understand this. Could you please tell us the exact error message you are getting and how can we reproduce it? A simple example project we can run as-is would be the easier way for us to reproduce the problem here.401kPensionGuru wrote:I installed the Mar 28 dnld and evrytime I run the exe I get an EEFACE -- this is an urgent matter as we are dead in water--we are using TEEChart in a very simple pie drawing in an Intraweb app...we previously had 2011 installed and it worked fine...
Try with:401kPensionGuru wrote:also the pie chart does not fill properly on the left side -- it looks like two disks -- see attached pic
Series1.RotationAngle:=359;
