Shape Series depens on calling sequence
gsachs
Post by gsachs » Fri Apr 13, 2012 5:25 pm
// This draws a correct shape
Series1.Clear;
Chart1.LeftAxis.SetMinMax( 0.0, 100.0 );
Chart1.BottomAxis.SetMinMax( 0.0, 100.0 );
Series1.X1 := 60;
Series1.Y1 := 50;
Series1.X0 := 20;
Series1.Y0 := 30;
// Different sequence , draws an incorrect shape, see attached images
Series1.Clear;
Series1.X0 := 20;
Series1.Y0 := 30;
Series1.X1 := 60;
Series1.Y1 := 50;
I use the shape series for reason that the rectangle tool does not size with zoom, which i need.
The shape series does size, but a shape is not movable or sizable with the mouse, which i need too.
Is there another way to honor both requirements ?
Gerhard
TeeChart InCorrectShape.JPG (41.59 KiB) Viewed 3675 times
TeeChart CorrectShape.JPG (38.74 KiB) Viewed 3686 times
Re: Shape Series depens on calling sequence
Post by Yeray » Mon Apr 16, 2012 12:29 pm
Hi Gerhard,
I think the easiest way to do this would be using a TRectangleTool. To zoom&scroll it with the chart, you could save the rectangle coordinates transformed to axes values (ie P0X, P0Y, P1X, P1Y) and redraw the tool with the reconverted values at OnZoom/OnUndoZoom/OnScroll events:
uses Series, TeeTools, Math;
var P0X, P0Y, P1X, P1Y: Double;
  Chart1.AddSeries(TFastLineSeries);
  Chart1.Axes.Bottom.SetMinMax(0,100);
  Chart1.Axes.Left.SetMinMax(0,100);
  with Chart1.Tools.Add(TRectangleTool) as TRectangleTool do
    Text:='my rectangle Tool';
    PositionUnits:=muPixels;
    OnDragged:=RectToolDragged;
    OnResized:=RectToolResized;
  P0X:=20;
  P0Y:=30;
  P1X:=60;
  P1Y:=50;
  redrawRectangleTool;
procedure TForm1.redrawRectangleTool;
  Chart1.Draw;
  with Chart1.Tools[0] as TRectangleTool do
    Left:=Chart1.Axes.Bottom.CalcPosValue(min(P0X,P1X));
    Top:=Chart1.Axes.Left.CalcPosValue(max(P0Y,P1Y));
    Width:=Chart1.Axes.Bottom.CalcSizeValue(abs(P1X-P0X));
    Height:=Chart1.Axes.Left.CalcSizeValue(abs(P1Y-P0Y));
procedure TForm1.recalcRectangleTool(tool: TObject);
  with tool as TRectangleTool do
    P0X:=Chart1.Axes.Bottom.CalcPosPoint(Left);
    P0Y:=Chart1.Axes.Left.CalcPosPoint(Top);
    P1X:=Chart1.Axes.Bottom.CalcPosPoint(Left+Width);
    P1Y:=Chart1.Axes.Left.CalcPosPoint(Top+Height);
procedure TForm1.RectToolDragged(Sender: TObject);
  recalcRectangleTool(Sender);
procedure TForm1.RectToolResized(Sender: TObject);
gsachs
Post by gsachs » Tue Apr 17, 2012 3:51 pm
Hello Yeray,
thank you for the information.
I will change the Shape series to a rectangle tool.
But there is still the behaviour where the displayed shape depends on the parameter sequence.
For me, it is clear now.
But maybe other people would save some investigation time if such behaviour is documented.
Gerhard Sachs
