Printing issue with TeeChart Pro 2011 for Delphi XE2
marder
Post by marder » Thu Mar 22, 2012 1:01 pm
Hi.
I encountered an issue whith the fonts when printing with TeeChart Pro 2011 for Delphi XE2.
With Delphi 2010 the printed export looks as expected:
With Delphi XE2 the fonts of the legend and the hints looks very strange:
I use TChart.PrintPartial() for printing.
Is this a known issue?
Is there a fix or workaround for this?
Thanks for your help!
Re: Printing issue with TeeChart Pro 2011 for Delphi XE2
Post by Narcís » Fri Mar 23, 2012 12:45 pm
Hi marder,
This works fine for me here with Delphi XE2 using this code:
uses VCLTee.Series, VCL.Printers;
  Chart1.AddSeries(TPieSeries.Create(Self)).FillSampleValues;
  Chart1.Legend.Alignment:=laBottom
procedure TForm2.Button1Click(Sender: TObject);
  Printer.Orientation:=poLandscape;
  Printer.BeginDoc;
  Chart1.PrintPartial(Rect(0,0,Printer.PageWidth,Printer.PageHeight));
  Printer.EndDoc;
Which TeeChart version are you using? Does this occur with different printers?
marder
Post by marder » Fri Mar 23, 2012 1:51 pm
Hi Narcis,
I tried the code you send me, but this however leads to the same result.
When I use the code in a simple sample project with chart and pie series default settings, all works as expected :(
Anyway, the printing works correctly with Delphi 2010.
I will try to build a sample project including my settings were this issue occurs.
Contact you soon...
marder
Post by marder » Fri Mar 23, 2012 1:52 pm
P.S.: This issue is not specific for one printer. I tried with several printers.
Post by Narcís » Fri Mar 23, 2012 2:20 pm
Hi marder,
Thanks for the feedback.
Yes, please, that will help.
marder
Post by marder » Fri Mar 23, 2012 2:46 pm
Hi Narcis.
I found the reason that causes this issue!
I am using TGDIPlusCanvas form unit VCLTee.TeeGDIPlus as Canvas for the chart.
Please add
Chart1.Canvas := TGDIPlusCanvas.Create;
to the OnCreate event of the main form to see this issue.
Note: I use TGDIPlusCanvas to prevent an issue with the Anti-Alias tools in TeeChart Pro 2011 which I reported before
(See: http://www.teechart.net/support/viewtop ... f=3&t=9180)
So what should I do now?
Do I have to decide between fancy chart in GUI or fancy chart in printed export :wink:
Post by Narcís » Fri Mar 23, 2012 3:11 pm
Hi marder,
I don't get strange fonts as you did using the code you posted. What about antialiasing GDI+ canvas and font?
var g: TGDIPlusCanvas;
  Chart1.Legend.Alignment:=laBottom;
  g:=TGDIPlusCanvas.Create;
  g.AntiAlias:=True;
  g.AntiAliasText:=gpfBest;
  Chart1.Canvas := g;
If the problem persists could you please let us know the exact TeeChart version you are using and attach a simple example project we can run "as-is" to reproduce the problem here?
marder
Post by marder » Mon Mar 26, 2012 9:56 am
Dear Narcis.
Please take a look at the printed chart with common canvas:
And here the printed chart with gdi+ canvas:
The printed font in the hints and legend looks quite strange.
In my version of TeeChart Pro "AntiAlias:=True" and "AntiAliasText:=gpfBest" are the default settings of TGDIPlusCanvas.
I see no effect when I set them again after creation.
From the "Release.txt":
Release Notes 17th November 2011
TeeChart VCL version 2011
Build 2011.04.41118
Please find a sample project here
http://download.jam-software.de/treesiz ... tPrint.zip
Thanks for your help and best regards.
Post by Narcís » Mon Mar 26, 2012 10:25 am
Dear marder,
Neither the images nor the examples project links are working. Could you please check them or attach the files in the forums?
marder
Post by marder » Mon Mar 26, 2012 11:17 am
Dear Narcis.
Sorry, the links are currently not available.
I attached the files to this post.
Thanks and best regards.
TestChartPrint.zip
pie chart print demo project
(82.19 KiB) Downloaded 1357 times
pie chart with gdi+ canvas
pie chart with common canvas
Post by Narcís » Mon Mar 26, 2012 11:59 am
Hi marder,
Thanks for the files. I see, fonts could be much better with PrintPartial. I have added the issue (TV52016107) to the bug list. In the meantime, I recommend you to use StretchDraw as explained here. I checked this works fine with your project.
marder
Post by marder » Mon Mar 26, 2012 3:08 pm
Dear Narcis.
Using StrechDraw() with a bitmap seems to work better.
I'm currently trying to include this to my existing code, which is not that easy since there is some other stuff printed beside the chart.
I will contact you again if I need additional help.
marder
Post by marder » Tue Mar 27, 2012 10:04 am
Dear Narcis.
Ok, I managed to bring text and chart (bitmap) together on one printed export.
Anyway, when using your workaround the resolution of the printed export is not as good as when using PrintPartial.
This is because, when generating the bitmap, we use the dimensions of the TChart component. For printing the dimensions of the printer are used, since we want to use the whole page.
In case of using the dimensions of the printer also for exporting the bitmap, the hints and the legend are shown unreadable small (See attachment).
Best regards.
pie chart with unreadable small hint and legend
Post by Yeray » Wed Mar 28, 2012 1:28 pm
Hi marder,
You could try to increase the marks and legend fonts before generating the image to be printed.
I'd also suggest you to take a look at the printing better article here
Post by Yeray » Wed Nov 07, 2012 12:18 pm
We've just checked it with the actual v2012.07 and the example you posted above now seems to produce nice fonts, using PrintPartial and GDI+
Could you please give it a try?
