Mac Ios compilation
rlebbar
Mac Ios compilation
Post by rlebbar » Tue Mar 06, 2012 11:37 am
I am a new user of "TeeChart Pro 2011" (Full Source Code).
I did not find the fmxtee_*.pas files to compile my project for Iphone
I installed TeeChart using the binary file.
I did not recompile the source files
Thanks for your help
Re: Mac Ios compilation
Post by Narcís » Wed Mar 07, 2012 2:19 pm
Hi rlebbar,
You need to compile the full sources for using TeeChart 2011 for iOS. You can use the Recompile tool provided with the source code installer. It will generate necessary units.
rlebbar
Post by rlebbar » Thu Mar 08, 2012 5:37 pm
Hi Narcis,
I used the Recompile tool provided with the source code installer, and it generated the fmxtee_*.* files (FMI folder).
But once in the Mac the build process failed with a Fatal: Internal error 200602041.
Here are the last 10 lines generated in the build process.
FMXTee_Canvas.pas(8985,5) Note: Local variable "Center" is assigned but never used
FMXTee_Canvas.pas(8986,5) Note: Local variable "Radius" is assigned but never used
FMXTee_Canvas.pas(10807,7) Note: Local variable "P0" is assigned but never used
FMXTee_Canvas.pas(2654,16) Hint: Local type "PPoints" is not used
FMXTee_Canvas.pas(13469,3) Note: Local variable "AlphaBlendChecked" not used
FMXTee_Canvas.pas(13470,3) Note: Local variable "CanUseWinAlphaBlend" not used
FMXTee_Canvas.pas(14328,15) Hint: Local type "PColorRGB" is not used
FMXTee_Canvas.pas(14333,14) Hint: Local type "PRGBList" is not used
FMXTee_Canvas.pas(15200,5) Note: Private field "TFilerAccess.FRootAncestor" is never used
FMXTee_Canvas.pas(16044,1) Fatal: Internal error 200602041
Fatal: Compilation aborted
Can i have a copy of your FMI folder so that i can finally generate my first example on Iphone ?
Thank you
rlebbar
Post by rlebbar » Mon Mar 12, 2012 11:07 am
Hi Narcis,
12 Days after ordering the TeeChart Pro v2011 components (with source code)
my first IPhone test example does not even compile !
I was expecting at least ONE working IPhone example that can be easily compiled and tested on the real device.
Is it possible to ask for a very basic sample with all the necessary source files ?
Please Help, it is urgent !
Post by Narcís » Mon Mar 12, 2012 11:31 am
Hi rlebbar,
Apologies for the long delay. I just send you an email with my FMI folder, our current TeeChart sources and some additional instructions. Could you please check if this solves the problem at your end? In the meantime I also asked my colleagues to arrange an iOS example for you.
rlebbar
Post by rlebbar » Mon Mar 12, 2012 3:04 pm
Hi Nircis,
I just downloaded your FMI folder and updated mine "/Developer/Embarcadero/fmi"
Then i started a new ios project with zero line of code, just a Tchart component
and generated the xcode project successfully.
Once in the Mac I tried to build the project using your fmi files.
This is what i get (The last 10 Lines);
FMXTee_Canvas.pas(9020,5) Note: Local variable "Center" is assigned but never used
FMXTee_Canvas.pas(9021,5) Note: Local variable "Radius" is assigned but never used
FMXTee_Canvas.pas(10844,7) Note: Local variable "P0" is assigned but never used
FMXTee_Canvas.pas(2666,16) Hint: Local type "PPoints" is not used
FMXTee_Canvas.pas(13506,3) Note: Local variable "AlphaBlendChecked" not used
FMXTee_Canvas.pas(13507,3) Note: Local variable "CanUseWinAlphaBlend" not used
FMXTee_Canvas.pas(14379,15) Hint: Local type "PColorRGB" is not used
FMXTee_Canvas.pas(14384,14) Hint: Local type "PRGBList" is not used
FMXTee_Canvas.pas(15251,5) Note: Private field "TFilerAccess.FRootAncestor" is never used
FMXTee_Canvas.pas(16095,1) Fatal: Internal error 200602041
You will notice that i have the same internal error as before even if the FMXTee_Canvas.pas file has heavily changed
Please do your best to get me out of a real problem with a late due work !
Post by Narcís » Mon Mar 12, 2012 4:30 pm
Just sent you an example project which works fine for me here with the iOS emulator. Can you please check if it works fine for you? You may need to change search paths to fit your TeeChart installation.
rlebbar
Post by rlebbar » Mon Mar 12, 2012 5:32 pm
Hi Narcis,
Sorry to insist, but i did not receive the project example yet.
r.lebbar
Post by Narcís » Mon Mar 12, 2012 7:01 pm
I used the same email with which you are registered in this forum board and I used to send you the FMI folder before. I resent the email again. Did you receive it now? Actually, it's quite small, I attach it here as well.
iOS_Demo.zip
(320.19 KiB) Downloaded 1641 times
rlebbar
Post by rlebbar » Mon Mar 12, 2012 7:16 pm
Hi Narcis,
Sorry but i did not receive it.
Yes you may send it to rlebbar@gmail.com
Thank you
rlebbar
Post by rlebbar » Mon Mar 12, 2012 7:44 pm
Hi Narcis,
I downloaded ios_demo.zip
I will test it and i will get back to you in a moment.
Post by Narcís » Mon Mar 12, 2012 7:47 pm
Ok, I sent it to the gmail address now. I also had edited my previous reply and attached it to my previous answer. Hope you get it now.
X-Ray
Post by X-Ray » Tue Mar 13, 2012 7:21 am
could please somebody share the knowledge where to put the FMI folder with the TChart PRO iOS sources on the MAC to get this example project compiling
under Xcode?
best regards,
X-Ray
rlebbar
Post by rlebbar » Tue Mar 13, 2012 2:43 pm
Hi Narcis,
Finally i have a simple workaround, and it works !
I started with your XCode and FMI 2012. It did not compile for me and generated a different error from what i had.
Then i compiled it in Delphi XE2 U3 generated the XCode and got the same error as before (Internal error 200602041)
Then i changed the target from Iphone to ios-device Here it compiled and generated the application.
Then i went back to your XCode (Probably generated by Delphi XE2 U4) and compiled it with FMI 2011.
It did compile correctly for both targets.
My first impressions :
Great but a little slow !. I am trying to find the best way to load data.
Does BeginUpdate .. EndUpdate improve the load time ?
Thank you Narcis.
PS. : X-RAY, You should put your files in "/Developer/Embarcadero/fmi"
Post by Narcís » Tue Mar 13, 2012 3:25 pm
Hi rlebbar,
Excellent, thanks for your feedback!
No, here you can find how BeginUpdate works. For optimizing TeeChart performance I recommend you to read the Real-time Charting article here.
Thank you Narcis.
You're very welcome!
