Contour Plot on unstructured GRID
Ideas and wishes for TeeChart
Alex
Post by Alex » Thu Aug 05, 2004 8:59 am
Hello!
A wish for the next Teechart Version :idea: : contour plot along unstructured grids (not regular ones). It would be very useful to plot simple finite element data (2d and 3d)...
E.g.:
Input:
a range of coordinates (x,y,z)
a field of element definitions (triangle, bricks, ...) (n1,n2,n3,...)
a range of node data (u1,u2,u3,...)
Output:
contour plot/lines along the above defined mesh :D
Best regards
Alex
Marjan
Post by Marjan » Tue Aug 17, 2004 10:56 am
Hi, Alex.
Perhaps this could be done by some kind of gridding algorithm which would use arbitrary 3d points to construct a grid which can in turn be used in surface or contour series. I just added this feature to TeeChart NET demo so you should be able to test it once new maintenance release is out.
Marjan Slatinek,
Alex
Post by Alex » Sun Dec 26, 2004 2:53 pm
Hi Marjan,
do you included this feature in the latest .NET release? If yes, where I can find it and how I can use it? Can you include this also in the AX-V7?
Thanks in advance and a merry christmas!
Alex
