How to get counts of breaks on each axis?
Oli
Post by Oli » Tue Feb 07, 2012 11:22 pm
I would like to get the counts of breaks on each axis (bottom, left, and right). I think the following code gives me the total number of breaks, but is there an easy way to find out to which axis each break belongs too?
Dim axisbreak As Steema.TeeChart.Tools.AxisBreaksTool = New Steema.TeeChart.Tools.AxisBreaksTool(tChart.Chart)
Dim NumBreaks as integer
NumBreaks=axisbreak.Breaks.Count
Oliver
Re: How to get counts of breaks on each axis?
Post by Sandra » Thu Feb 09, 2012 4:51 pm
Hello Oliver,
The way as you get the number of AxisBreak are you add in your Chart is correct and If I had to suggest you a way to count the number of breaks, I would recommend the code you attached in your post.
Oli
Post by Oli » Thu Feb 09, 2012 11:21 pm
Thanks Sandra,
I have overseen the properties axisbreak.Axis=tchart.Axes.Bottom
to link the breaks to an axis
However, unfortunately I have other problems with the axis breaks using Teechart pro V2011 (4.1.2012.1032). All problems occur with charts produced with the Teechart assemblies (without DewResearch).
First, adding two breaks in a single axis causes the axis to be drawn through the first gap of the breaks. See attachements.
Secondly, I can not load charts as native format if the chart contains axis breaks. The following exception occur. The code works fine for charts not having any breaks.
Post by Sandra » Fri Feb 10, 2012 4:01 pm
Hello Oli,
Next code works fine for me in last version of TeeChartFor.Net 2012:
            //InitializeChart.
            tChart1.Series.Clear();
            line1.FillSampleValues(20);
            //AxesBreaks.
            Steema.TeeChart.Tools.AxisBreaksTool axisbreak = new Steema.TeeChart.Tools.AxisBreaksTool(tChart1.Chart);
            Steema.TeeChart.Tools.AxisBreak axisBreak1 = new Steema.TeeChart.Tools.AxisBreak(axisbreak);
            Steema.TeeChart.Tools.AxisBreak axisBreak2 = new Steema.TeeChart.Tools.AxisBreak(axisbreak);
            axisBreak1.StartValue = 4;
            axisBreak1.EndValue = 6;
            axisBreak2.StartValue = 15;
            axisBreak2.EndValue = 17;
            axisbreak.Axis = tChart1.Axes.Bottom;
            axisbreak.GapSize = 20;
Can you please try if previous code works as you expect?
I have added it in wish-list with number [TF02016030] to be consider it inclusion in next maintenance releases of TeeChart.Net.
Oli
Post by Oli » Fri Feb 10, 2012 10:23 pm
Hi Sandra,
regarding the axis drawn through the gap, the your code does not resolve the problem, and is equavalent to the code I am using. You said you are using Teechart.Net V2012, but I checked the download page under Client access and the latest version available for download is TeeChartNET2011_4.1.2012.01030. So I am a little confused, and I would appreciate if you can confirm that you have used another version. If that is the case, how to download the latest version Teechart.net V2012?
Thanks for adding the issue with loading charts containing axis breaks on the wish list. But I think it should go on the bug list...it causes an exception, and makes the use of the binary format rather limited if I rely on axis breaks. I need also to use the binary format to save and load chart for later editing. So I would appreciate if this can be handled with a higher priority rather being on the wish list. I would appreciate the efforts.
Oliver
Post by Sandra » Tue Feb 14, 2012 4:11 pm
Hi Oli,
Sorry, for the confusion. The last V2012 is build 4.1.2012.01030, therefore, you can use the last version of TeeChart.Net.
Oli
Post by Oli » Sun Mar 18, 2012 10:46 am
Hi Sandra,
loading charts with axis breaks from the binary format works now with the latest version Teechart2012 4.1.2012.2282 ...thank you very much.
Oli
Post by Sandra » Mon Mar 19, 2012 10:01 am
Hello Oli,
I am glad that your problem have solved in last version of TeeChartFor.Net. :)
