Curve Fitting...
Curve Fitting...
I have a scattered point series on a chart and I want to fit a curve to it - this should be simple right?
I add a statistics tool to the chart and assign it to the point series and check the Curve fitting check box. When I run the code the line series which as been added automatically by the addition of the tool is still not visible.
Is there a step I'm missing here?
I am using v8.06 and have searched the user base and found mention of tutorial 7 on this subject - which I can't find - in fact the .hlp file is not readable using Windows 7. Is there any chance there is a .pdf of the help?
Bruce.
Bruce.
Re: Curve Fitting...
Hi Bruce,
If you still have problems with it, please don't hesitate to let us know.
http://www.teechart.net/support/viewtop ... s+7#p49181
The following code works fine for me here.Metman wrote:I have a scattered point series on a chart and I want to fit a curve to it - this should be simple right?
uses TeeSeriesStats, CurvFitt, Series;
var tmp: TCurveFittingFunction;
Chart1.View3D:=false;
Chart1.AddSeries(TPointSeries).FillSampleValues;
Chart1[0].Title:='Source';
with Chart1.Tools.Add(TSeriesStatsTool) as TSeriesStatsTool do
Series:=Chart1[0];
tmp:=TCurveFittingFunction.Create(Self);
tmp.ParentSeries:=Chart1.AddSeries(TFastLineSeries);
tmp.ParentSeries.DataSource:=Chart1[0];
tmp.ParentSeries.FunctionType:=tmp;
tmp.ParentSeries.Title:='Curve Fitting';
Regarding the hlp files:Metman wrote:I am using v8.06 and have searched the user base and found mention of tutorial 7 on this subject - which I can't find - in fact the .hlp file is not readable using Windows 7. Is there any chance there is a .pdf of the help?
Hi Yeray
Thanks for the quick reply - yes that code snippet works - but although I have been programming for years there is more than a little magic going on in it even though its not many lines long!
It must be possible to do this through the tool dialog without resorting to doing it dynamically?
I notice when I look at previous replies to this problem they always supply users with a dynamic solution - that's why I would just appreciate it if you could maybe talk me through doing it this way?
By the way I did download the Win help and I can now read the TeeChart help. The trouble with that it's fairly basic and as far as I can see does it talk you through adding the stats tool through the IDE - has anyone ever thought of producing an Ebook for TeeChart.
Bruce.
Bruce.
- Statistics tool dialog
- Capture1.png (44.1 KiB) Viewed 20064 times
Hi Bruce,
I'm not sure to understand what is a "dynamic solution".
I can see the Curve fitting both using the code above in a new application with just a chart on the form, and also adding a Point series with some random values, adding the Statistics tool, setting the tool series to be the point series and checking the "Curve fitting" checkbox. The only difference I see is that doing it at design time the function is drawn in a TPointSeries while I used a TFasTLineSeries by code.
I'm using v8.08 in D2010 here.
We usually try to share and comment the examples in code because it's easier to miss something when commenting a list of steps to follow at designtime, etc. A code snipped or a complete example is the best way we've found to ensure both sides are talking about the same.Metman wrote:Thanks for the quick reply - yes that code snippet works - but although I have been programming for years there is more than a little magic going on in it even though its not many lines long!
I've just emailed you the printable version of the manual.Metman wrote:By the way I did download the Win help and I can now read the TeeChart help. The trouble with that it's fairly basic and as far as I can see does it talk you through adding the stats tool through the IDE - has anyone ever thought of producing an Ebook for TeeChart.
Hi Yeray
What I suppose I mean by 'dynamic solution' is I want to add the series and the curve fitting tool at design time - your solution is dynamic because the curve fitting class is instantiated at run time when the form is created.
I can add a curve fitting tool to my graph at design time and point it at a series but I can't make the curve fitting series display!
Your code snippet works fine but I want to be able to do it at design time and not have to dynamically add any code.
This is the very simple procedure I use to plot the scattered point data - the point series displays fine but no curve is there a method I have to call to refresh the curve fitting and redraw the fast line?
Thanks for the RTF even though it is a little out of data.
Bruce.
procedure PlotGraph(grid: TAdvStringGrid);
var
r : integer;
t : double;
Series1.Clear;
with grid do
for r:=2 to RowCount-1 do
t:=StrToFloatDef(Cells[2,r],missing);
if t<>missing then
Series1.AddXY(Ints[1,r],t);
Bruce.
Hi Bruce,
That's what I do in Delphi 2010 + TeeChart Pro v8.08.
At design time:
- Create a new Delphi project
- Add a Chart on the form.
- Set the Chart to 2D.
- Add a Point series.
- Set the point series values to "manual" (Series\Data Source).
- Add an Statistics tool and assign Series1 to it.
- Select "Curve fitting" checkbox in the statistics tool.
With this, when I run the application, I see exactly the same I see at designtime: Now, if you add some more values to Series1, for example adding a button that does this:
When you run this button Series1 has new values, but the function(s) in the Statistics tool don't know that so you have to refresh their source.
In the case above, we know Series1 (the source) has the index 0 and the Series2 (the series linked to the Curve fitting function) has the index 1. Then you should call the following at the end of Button1Click:
Does it solve your doubts?
At design time:
var i: Integer;
for i:=0 to 9 do
Series1.Add(Series1.YValues.MinValue + Random(Round(Series1.YValues.Range)));
Chart1[1].CheckDataSource;
Hi Yeray
Sorry for not replying yesterday. Thanks for your steps to add a curve they work fine but it still does not fix my problem although I can now plot a curve!
The embedded image (1) shows you the problem - I plot a scattered temperature series for the years between 1878 and 2012 from a list of randomly sorted values like this:
1878 12.5
1969 11.7
1990 11.0
1898 11.4
1918 11.4
1884 11.4
1899 10.1
1901 10.1
1976 10.9
1902 10.0
1937 11.7
1981 10.4
etc etc...
Because the chart auto-scales the real values are huddled up on the right whilst the best fit curve starts at 0 and plots 25 values on the extreme left with Y values that don't bear any relation to those of the temperature values which are always around 10-13.
I then decided to save the data and load it manually as space delimited text (file attached) and got the results you see in the second screen shot (2).
Should the series be sorted for the curve fitting to work and why are the results so high?
Bruce.
1878 12.5
1969 11.7
1990 11.0
1898 11.4
1918 11.4
1884 11.4
1899 10.1
1901 10.1
1976 10.9
1902 10.0
1937 11.7
1981 10.4
etc etc...
Bruce.
Hi Bruce,
I'm trying to reproduce the problem with an as simple as possible example, but it seems to work fine for me here. Could you please try it?
If it gives you the same result than me, maybe you can find the relevant difference between this example and your application.
I you don't find it, please, try to arrange a simple example project we can run as-is to reproduce the problem here.
uses CurvFitt, Series;
var curveFitFunct: TCurveFittingFunction;
curveFitSEries: TFastLineSeries;
with Chart1.AddSeries(TPointSeries) do
Title:='Source';
AddXY(1878, 12.5);
AddXY(1969, 11.7);
AddXY(1990, 11.0);
AddXY(1898, 11.4);
AddXY(1918, 11.4);
AddXY(1884, 11.4);
AddXY(1899, 10.1);
AddXY(1901, 10.1);
AddXY(1976, 10.9);
AddXY(1902, 10.0);
AddXY(1937, 11.7);
AddXY(1981, 10.4);
curveFitFunct:=TCurveFittingFunction.Create(Self);
curveFitSeries:=Chart1.AddSeries(TFastLineSeries) as TFastLineSeries;
curveFitSeries.FunctionType:=curveFitFunct;
with curveFitSeries do
Hi Yeray
Your simple project works OK but I think I now know why the curve never appears - it simply can't fit it to the data - its too scattered.
See what you think of this project that I've attached - this has all the data points and not just a few - and the curve still does not get plotted.
You may well be able to get something to plot if you play around with the parameters...
Bruce.
Bruce.
- Test Project.zip
- (2.7 KiB) Downloaded 1263 times
Doing some very little changes it seem to work fine for me here
Hi Yeray
So all it all seemed to be down to the fact that I didn't force the curve to redraw by not calling the
method - so simple - thanks for your help
Bruce.
Bruce.
