Last MARK not showing in a line series
Wieselberg
Post by Wieselberg » Fri Jan 13, 2012 4:22 pm
After upgrading to ActiveX 2011 we do not see the lst MARK in a line series. The datapoint is active, so we can view tooltips even for that point, but the mark is missing. Here is some client-side code we have dealing with marks and the image below it.
function changeMark(theSIndex,SeriesIndex) {
var theX
var theY
var adjustedIndex
// Adjust from index to value
adjustedIndex = parseInt(theSIndex) + 1;
// Add Annotation tool to chart
if (dpToolFlag == false) {
Chart1.Tools.Add(10);
dpToolFlag = true;
//dpToolItemNumber = numTools + 1;
dpToolItemNumber = Chart1.Tools.Count - 1;
if(dpToolItemNumber < 0)
dpToolItemNumber = 0;
numTools = dpToolItemNumber - 1;
Chart1.Tools.Items(dpToolItemNumber).asAnnotation.Shape.CustomPosition = 1;
// Calulate X pos and Y pos from index
theX = Chart1.Series(SeriesIndex).CalcXPos(theSIndex);
theY = Chart1.Series(SeriesIndex).CalcYPos(theSIndex);
// Set position of annotation based on X and Y values
Chart1.Tools.Items(dpToolItemNumber).asAnnotation.Shape.Left = theX;
Chart1.Tools.Items(dpToolItemNumber).asAnnotation.Shape.Top = theY;
// Set the string that will appear in annotation
Chart1.Tools.Items(dpToolItemNumber).asAnnotation.Text = "Point: " + adjustedIndex;
example of missing mark
Wieselberg
Re: Last MARK not showing in a line series
Post by Wieselberg » Mon Jan 16, 2012 3:11 pm
I did some further testing on this. This problem seems to only happen on wide-screen monitors. Standard width monitors show the mark properly. This also only happens with ActiveX. If an image file is loaded then the mark appears at the last point.
Post by Yeray » Tue Jan 17, 2012 3:58 pm
Hi Wieselberg,
Are you using the latest version available?
http://www.teechart.net/support/viewtop ... =1&t=12950
The following code seems to work fine with it:
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scPoint
Wieselberg
Post by Wieselberg » Thu Jan 19, 2012 3:26 pm
I was not using maintenance release 5 at the time. I had 4 for the test. Is there a known issue that you resolved with 5?
Post by Yeray » Fri Jan 20, 2012 4:07 pm
Hi Wieselberg,
Yes, take a look at this thread (note TeeChart AX is a wrapper from the VCL version so the changes applied to the first also affect the second)
Wieselberg
Post by Wieselberg » Thu Jan 26, 2012 3:39 pm
Maintenance release 5 appears to have fixed this issue. Thank you very much! :D
