Cell Color in ColorGrid
Planoresearch
Post by Planoresearch » Sat Dec 24, 2011 12:55 pm
Hi Steema Support,
We are using TeeChart for .NET2010. I am trying to create a color grid series I which we are putting data in the manner as in following code. I have put red color in each cell of grid. I am facing problem when I am trying to zoom the chart. The color of cells are changing as soon as I zoom the chart. You can see it in attached picture.
The code is:
            tChart1.Header.Text = "";
            tChart1.Walls.Visible = false;
            tChart1.Chart.Panel.Color = Color.Transparent;
            tChart1.Zoom.Allow = false;
            tChart1.Axes.Bottom.Automatic = true;
            tChart1.Axes.Bottom.AxisPen.Color = Color.Gray;
            tChart1.Axes.Left.Automatic = true;
            tChart1.Axes.Left.AxisPen.Color = Color.Gray;
            tChart1.Zoom.Allow = true;
            clrGrid = newColorGrid();
            clrGrid.Pen.Color = Color.Blue;
            clrGrid.UsePalette = true;
            clrGrid.UseColorRange = false;
            clrGrid.Pen.Visible = true;
int k = 0;
for (int i = 1539; i < 2819; i++)
                k++;
for (int j = 0; j < 5976; j = j + 4)
                    clrGrid.Add(i,k,j, Color.Red);
            tChart1.Series.Add(clrGrid);
In above code “i” represents to x ,”j” represents to y and “k” is some value which represent the z value. Currently I am putting red color to all cell later I will put color on the basis of z values.
Re: Cell Color in ColorGrid
Post by Sandra » Tue Dec 27, 2011 11:57 am
Hello Planoresearch,
I have modify a little your code to work with less data. Moreover, I have added IrregularGrid=true. Please see next:
        ColorGrid clrGrid;
            /*Chart*/
            tChart1.AutoRepaint = false;
            clrGrid = new ColorGrid(tChart1.Chart);
            clrGrid.UsePalette = false;
            clrGrid.IrregularGrid = true;
            int k = 0;
            for (int i = 153/*9*/; i < 281/*9*/; i++)
                k++;
                for (int j = 0; j < 597/*6*/; j = j + 4)
                    clrGrid.Add(i, k, j, Color.Red);
            tChart1.AutoRepaint = true;
            tChart1.Refresh();
Can you tell us if using previous code your problem appears? On the other hand, can you tell us which version are you using?
Planoresearch
Post by Planoresearch » Wed Dec 28, 2011 10:24 am
Hi Sandra,
Thanks for reply. Given code is exactly working fine. Our problem is resolved.
Thanks & Regards,
Plano Research
