Annotation Tool drawing problem
Bert B.
Post by Bert B. » Tue Nov 08, 2011 9:09 am
In the attached sample project I have 2 chart with 2 Annotation tools with a custom position.
Following advise in this forum the position of the Annotation tool is set in the OnAfterDraw event of the chart.
With the checkbox Chart1 can be made (in)visible. In the following OnAfterDraw event the Annotation tool is not drawn in the correct position, only after a second OnAfterDraw event.
What do I have to do to draw the Annotion tool in the correct place after (un)checking the checkbox?
Bert
TeeChartAnnotationTool.rar
(1.94 KiB) Downloaded 638 times
Re: Annotation Tool drawing problem
Post by Yeray » Wed Nov 09, 2011 9:57 am
Hello Bert,
I've found a quite ugly workaround:
procedure TForm1.CheckBox1Click(Sender: TObject);
  Chart1.Visible := CheckBox1.Checked;
  Chart2.Draw;
  ChartTool2.Repaint;
Or another one maybe a little bit prettier:
var Annotation2OldVal: Integer;
procedure TForm1.FormShow(Sender: TObject);
   LabelVersion.Caption := TeeMsg_Version;
   Annotation2OldVal:=-1;
procedure TForm1.Chart2AfterDraw(Sender: TObject);
  with ChartTool2 do
    Top := ParentChart.Height - Shape.Height - 10;
    if (Annotation2OldVal=-1) or (Top<>Annotation2OldVal) then
      Annotation2OldVal:=Top;
      Chart2.Draw;
Bert B.
Post by Bert B. » Wed Nov 09, 2011 12:14 pm
Hello Yeray,
Thanks for the workaround. I suppose that this will get fixed in an official release eventually?
Bert
Post by Yeray » Wed Nov 09, 2011 2:22 pm
Hello Bert,
I don't think we can consider it as a bug, but a per design behaviour.
Note that, when the code in your AfterDraw event is executed, the chart is already drawn and so is the annotation. So, changing the position of an element that has already been drawn, the new element position will logically be applied in the next repaint.
I'm not sure if my explanation has been clarifying... :oops: Don't hesitate to ask for another one if you get confused! :)
Bert B.
Post by Bert B. » Wed Nov 09, 2011 2:38 pm
Hello Yeray,
I understand your explanation.
In TeeChart there are several options to place the annotation tool.
And we have the choice for a custom position.
In my situation I want the annotation in the bottom left corner, but not exactly in the position it is placed by TeeChart.
It would be cool if TeeChart would treat the custom values as offsets regarding to the chosen position. This would remove the need for my OnAfterDraw code.
Bert
Post by Yeray » Thu Nov 10, 2011 3:20 pm
Hello Bert,
Bert B. wrote:It would be cool if TeeChart would treat the custom values as offsets regarding to the chosen position. This would remove the need for my OnAfterDraw code.
This would affect other customers who already are using the actual absolute custom coordinates. But we could add a property, for example named useRelativeCoords, that would be false by default. And setting it to true the Top and Left positions would count from the Auto alignment position set.
I've added it to the wish list to be implemented in future releases (TV52015825)
