Pie Chart Values
MikeTheLad
Pie Chart Values
Post by MikeTheLad » Fri Oct 21, 2011 8:47 am
My pie chart has numbers on outside and work fine until the a few sections are few small, as attached. Is this anyway to say move the numbers futher out and have lines to the relevant pie, or is the an alternative solution.
Re: Pie Chart Values
Post by Narcís » Fri Oct 21, 2011 9:43 am
Hi MikeTheLad,
Yes, you can do something similar as in the example Pep posted here.
