Error in TeCanvas
johnnix
Error in TeCanvas
Post by johnnix » Thu Oct 20, 2011 8:32 am
My application is running fine for several years now on many clients but today for the very first time a client reported an error (See attached picture). What could be the issue here provided the fact that the application works ok on so many machines?
Kindest regards
johnnix
Re: Error in TeCanvas
Post by johnnix » Thu Oct 20, 2011 8:46 am
Ok, here is an update. The user just reported that when my application starts they first receive the attached error (app is running on a WinXP SP3 machine).
Post by Narcís » Thu Oct 20, 2011 9:10 am
Hi johnnix,
We are aware of a similar issue (TV52015296) which was discussed in this thread. Can you please ask your client if they reproduced the issue in similar circumstances?
Could you please provide more detailed information or an example project to reproduce the problem here?
johnnix
Post by johnnix » Thu Oct 20, 2011 9:20 am
Hello Narcis,
I will see if the user wished to run a test app and reproduce the error. I am not able to reproduce the error here
johnnix
Post by johnnix » Fri Oct 21, 2011 5:23 am
Is there any work around for this error at all? Unfortunately I lost this client :(
Kindest regards
Post by Narcís » Fri Oct 21, 2011 7:13 am
Hi johnnix,
An option is try compiling the application with assertions disabled as explained at the thread I pointed you.
