Axis
MikeTheLad
Axis
Post by MikeTheLad » Fri Oct 14, 2011 1:18 pm
I want to remove the grid lines, which if I make the Axis.Vsible = false does this, but I still require the scale on the left hand side which is lost when I turn make visible = false
Re: Axis
Post by Sandra » Fri Oct 14, 2011 2:51 pm
Hello MikeTheLad,
If you want remove lines, I recommend that use property of Axis Grid.Visible = false as do in next line of code:
tChart1.Axes.Bottom.Grid.Visible = false;
MikeTheLad
Re: Axis
Post by MikeTheLad » Mon Oct 17, 2011 12:13 pm
Thanks, this only does the vertical lines, I also need to loose the horizontal, have tried several option, none of which have worked
Re: Axis
Post by Sandra » Mon Oct 17, 2011 2:20 pm
Hello MikeTheLad,
You need do the same as you do with vertical lines of Grid. Please see next line of code:
tChart1.Axes.Left.Grid.Visible = false;
Can you tell us if previous lines of Code works as you expected?
MikeTheLad
Re: Axis
Post by MikeTheLad » Tue Oct 18, 2011 8:15 am
Thanks, this is what I wanted
