I am having a problem getting the chart to draw properly inside an MS Access report. I am using Access 2010 and TeeChart v8.0.1.1
I have taken over a project from a previous developer, and I am trying to learn how to use TeeChart. Here are some of the problems that I am having:
I have v8.0.1.1 installed on my machine, but some of the existing graphs in the program are an older version v4 I believe. When I try to open the forms/reports containing these older graphs I get an error saying that I do not have a license for the control. How do I access these older controls?
When I create a new graph on a report, the graph does not draw itself to the borders of the control. There seems to be a second border inside the control border and the graph draws to this inner border. How do I set the dimensions of this inner border? Searching through the forum, I found a reference to the frame. Is this inner border the frame?
When the graph is displayed on the report, part of the graph is beyond the edge of the control, and not displayed. As I scroll the report page, the graph also scrolls farther outside the edge of the control. How do I get the graph to draw correctly on the report page and not scroll outside of the control border?
Thank you
Brad
Problems with an Access Report
- As the report is scrolled down, the graph moves upwards inside the control borders
- Image.jpg (154.1 KiB) Viewed 12136 times
Re: Problems with an Access Report
Hello Brad,
If it only happens in a new application, could you please send it to us so we can reproduce the problem here?
I'm afraid it's not possible to have two different TeeChart version in a same project. Note that all TeeChart versions use the same namespaces so they would conflict.ronm wrote:I have v8.0.1.1 installed on my machine, but some of the existing graphs in the program are an older version v4 I believe. When I try to open the forms/reports containing these older graphs I get an error saying that I do not have a license for the control. How do I access these older controls?
Can you see this problems in the Teedemo.mdb example shopped with the installation? It should be in your installation folder, into "\Examples\MSOffice\VBA Access".ronm wrote:When I create a new graph on a report, the graph does not draw itself to the borders of the control. There seems to be a second border inside the control border and the graph draws to this inner border. How do I set the dimensions of this inner border? Searching through the forum, I found a reference to the frame. Is this inner border the frame?
Does this mean that I have to go through my project and replace the graphs that already exist? Is there any way to do this and preserve the settings that were defined in the control and not code?Yeray wrote:I'm afraid it's not possible to have two different TeeChart version in a same project. Note that all TeeChart versions use the same namespaces so they would conflict.ronm wrote:I have v8.0.1.1 installed on my machine, but some of the existing graphs in the program are an older version v4 I believe. When I try to open the forms/reports containing these older graphs I get an error saying that I do not have a license for the control. How do I access these older controls?
It does not happen in the Teedemo.mdb file. I have attached a sample project which replicates the problem.Yeray wrote:Can you see this problems in the Teedemo.mdb example shopped with the installation? It should be in your installation folder, into "\Examples\MSOffice\VBA Access".ronm wrote:When I create a new graph on a report, the graph does not draw itself to the borders of the control. There seems to be a second border inside the control border and the graph draws to this inner border. How do I set the dimensions of this inner border? Searching through the forum, I found a reference to the frame. Is this inner border the frame?
If it only happens in a new application, could you please send it to us so we can reproduce the problem here?.
- TeeChart.zip
- Sample project
- (100.66 KiB) Downloaded 914 times
Hello ronm,
TeeChart have a Tool to convert application in old TeechartActivex to a newest TeeChartActivex and I recommend you, use it. You can find the tool in TeeChart Pro v2011 ActiveX Control\Utilities.Does this mean that I have to go through my project and replace the graphs that already exist? Is there any way to do this and preserve the settings that were defined in the control and not code?
Thank you for the code. We can reproduce your problem and I have added it in bug list report with number[TA05015779]. We will be try to fix it for next maintenance releases of TeeChart.net.It does not happen in the Teedemo.mdb file. I have attached a sample project which replicates the problem.
Does the conversion tool work on MS Access VBA programs? I could only find tools for VB, VC++, and VS.Net.Sandra wrote:Hello ronm,TeeChart have a Tool to convert application in old TeechartActivex to a newest TeeChartActivex and I recommend you, use it. You can find the tool in TeeChart Pro v2011 ActiveX Control\Utilities.RonM wrote: Does this mean that I have to go through my project and replace the graphs that already exist? Is there any way to do this and preserve the settings that were defined in the control and not code?
How soon will you have a maintenance release for TeeChart v8? We need either a fix or a workaround ASAP.Sandra wrote:Thank you for the code. We can reproduce your problem and I have added it in bug list report with number[TA05015779]. We will be try to fix it for next maintenance releases of TeeChart.net.RonM wrote:It does not happen in the Teedemo.mdb file. I have attached a sample project which replicates the problem.
Brad
Hello Brad,
Sorry for the delay. We are working to find a solution with the problem with this thread and we inform you asap.
Hello Brad,
I have sent you an e-mail where there is a specific OCX of TeeChartActivex8 has the bug fixed.
