sort by grouped month
I have a series grouped by month.
I want it to sorted correctly.
How?
How?
- ChartSort.zip
- (112.02 KiB) Downloaded 887 times
Re: sort by grouped month
Hi jls,
If you go to the Series -> General tab how are series sorted? You should try sorting them by text. If the problem persists could you please attach a simple example project we can run "as-is" to reproduce the problem here?
here is a sample
- Project2.zip
- (102.45 KiB) Downloaded 904 times
Hi jls,
To achieve what you request you can change your datasource to use a dataset like this:
Which produces this chart:
Is that what you were looking for?
No
It should be grouped my month and sorted by month (dec2010,jan2011,feb2011....)
It can be more than one row in each month
Jørgen
Jørgen
Hi Jørgen,
Ok, I see. We have done some modifications to DBChart.pas here that would let you achieve what you request. Since you are a source code customer you could try doing the modifications below to your code. If that's what you are looking for we will investigate further if those modifications can make into a production release.
Go to TCustomDBChart.RefreshDataSet method, at AddToSeries a nested method of another nested method(ProcessRecord), change this:
for this:
Also, in the same nested method (ProcessRecord) in TCustomDBChart.RefreshDataSet method, change:
to this:
Please let us know if that's what you are looking for.
ASeries.Add(tmpMand,tmpXLabel,tmpColor);
if (GroupPrefix=dgNone) then
ASeries.AddXY(tmpNotMand,tmpMand,tmpXLabel,tmpColor);
if Assigned(tmpData) then
tmpNotMand:=TField(tmpData).AsFloat
// ADataSet.GetFieldData(TField(tmpData), @tmpNotMand) // v7 speed opt.
tmpNotMand:=0;
tmpNotMand:=TField(tmpData).AsFloat;
Better, but the x location of the bars is not correct.
It should not care about the date, just the month.
Jørgen
Jørgen
- Untitled.png (53.11 KiB) Viewed 19114 times
Hi Jørgen,
With the code as it stands the bars are set at the location of the date of the last value in that month. We assume that you would prefer the bars to centre on that month. Is that correct?
Think it is tha same for me if it is first, midle or last day in the month, the problem is that it doesn't work like this for me. It uses the actual date. Take a look at the second image.
Jørgen
Jørgen
Hi Jørgen,
Yes, we have a new solution proposal. Besides the changes I posted here last week you should also make a change at TCustomDBChart.RefreshDataSet in DBChart.pas at its nested CalcXPos function. You'll need to do the following:
1. Add a Word variable called WeekNum.
2. Replace this code:
for this:
3. Finally add DateUtils at class' uses section.
Is that what you expected? Notice there are some more DateTime grouping options now.
dgWeek: result:=TeeStr(DateToWeek(tmpNotMand,Year))+'/'+TeeStr(Year);
dgWeekDay: result:={$IFDEF D15}FormatSettings.{$ENDIF}ShortDayNames[DayOfWeek(tmpNotMand)];
dgMonth: result:=FormatDateTime('MMM/yy',EncodeDate(Year,Month,1));
dgQuarter: result:=TeeStr(1+((Month-1) div 3))+'/'+TeeStr(Year); // 5.02
dgYear: result:=FormatDateTime('yyyy',EncodeDate(Year,1,1));
dgWeek: begin
WeekNum := DateToWeek(tmpNotMand,Year);
result:=TeeStr(WeekNum)+'/'+TeeStr(Year);
tmpNotMand := EncodeDateWeek(Year,WeekNum,4);
dgWeekDay: begin
DecodeDateWeek(tmpNotMand,Year,WeekNum,Day);
tmpNotMand := Day;
dgMonth: begin
result:=FormatDateTime('MM/yy',EncodeDate(Year,Month,1));
tmpNotMand := EncodeDate(Year,Month,15);
dgQuarter: begin
result:=TeeStr(1+((Month-1) div 3))+'/'+TeeStr(Year); //5.02
tmpNotMand := EncodeDate(Year,((1+((Month-1) div 3)-1)*3)+2,1);
dgYear: begin
tmpNotMand := EncodeDate(Year,6,30);
This is exactly what I want,
Hi Jørgen,
Thanks for your feedback. We will include this in the next maintenance release then.
