Last week I updated my TChart (ActiveX) software from 2010 to 2011.
After that I noticed that my graph was not complete anymore:
One of the series is defined as a line with cicular points. With 2010 all points are visible , with 2011 the last point is missing.
To demostrate this I first started my application with TChart2010.ocx and made a printscreen. After that I de-installed 2010 and installed TChart2011.ocx and made another printscreen. I put these together with a part of the code into the attached document.
I hope this will help you to improve your software.
Best regards,
Stef Dekker
Update 2011: the last point is missing
- Example screens.zip
- Screens
- (134.16 KiB) Downloaded 668 times
Re: Update 2011: the last point is missing
Hi steffan,
Thanks for reporting. I could reproduce the problem with v2011.0.0.4. Some changes were done on this field last week and I have checked the issue has been fixed for the next maintenance release.
