Available when ?
bdw
Available when ?
Post by bdw » Sun Sep 04, 2011 11:20 pm
Hello Steema,
Do you have a Beta or release date available for a TChart FireMonkey compatible version ?
Can you tell me is the version that comes with XE2 compatible with FireMonkey ?
Regards,Brett.
Re: Available when ?
Post by Yeray » Mon Sep 05, 2011 8:27 am
Hello Brett,
Let me start for the last question:
bdw wrote:Can you tell me is the version that comes with XE2 compatible with FireMonkey ?
Yes, the TeeChart Standard version that comes with XE2 supports FireMonkey (and 64bit as well).
bdw wrote:Do you have a Beta or release date available for a TChart FireMonkey compatible version ?
As said above, TeeChart Standard is already in the IDE. On the other hand, I'm afraid I can't tell you a date for TeeChart Pro to support XE2, but we'll try to publish it asap.
bdw
Post by bdw » Mon Sep 05, 2011 9:52 pm
Thanks for your response.
I take it that there is no FM OS X support at this stage ?
When trying to compile under XE2 in a C++ basic app I get the following error when trying to compile for OSX32 :-
[ILINK32 Error] "ilink32" exited with code 3.
Brett
Post by Narcís » Tue Sep 06, 2011 7:03 am
Hi Brett,
Exactly, source code will be necessary for that.
Post by Narcís » Wed Sep 07, 2011 2:59 pm
Hi Brett,
Sorry, my bad. I've been told that my previous reply is wrong. I'll confirm this and get back to you with a reply to your inquiry ASAP.
Post by Narcís » Fri Sep 09, 2011 2:53 pm
Hi Brett,
Ok, sorry for the confusion. I didn't distinguish between Mac OS X and iOS compilation :oops:. TeeChart source code will only be necessary for iOS projects, you can already compile for OSX.
Regarding your problem, I could reproduce it here and added the issue (TF02015731) to the defect list to be fixed for next releases.
BTW: Here you'll find latest official update about TeeChart and FireMonkey support.
bdw
Post by bdw » Sat Sep 10, 2011 4:46 am
Thanks for the update, much appreciated.
