2010.0.0.4 shows japanes/korean charakters
Like the title says. I donwloaded the latest TC2010.0.0.4 and installed it.
Now the editor is not in english but, i guess, japanes or korean.
What is wrong here?
Greetings
Jack
What is wrong here?
Greetings
Jack
Re: 2010.0.0.4 shows japanes/korean charakters
BTW the OCX (TeeChart2011.ocx) shows under properties, details, file version: 2010.0.0.3 !
Hello Jack,
Did you have another version installed in that machine?
Can you change it in the design time "Language..." option (in the contextual menu)?
I cannot reprodue it here. It shows the editors in English to me, both in design time and runtime.Jack007 wrote:Now the editor is not in english but, i guess, japanes or korean.
That's right. We're investigating what happened here. I'll be back here asap.Jack007 wrote:BTW the OCX (TeeChart2011.ocx) shows under properties, details, file version: 2010.0.0.3 !
Well, the only thing i did was to uninstall the previous version (2010.0.03). After that i installed the new version.
It behaves the same under design and runtime.
When running the feature demo (new series, rose, edit) it also shows japanese/korean (see attachment).
Greetings,
Jack
Greetings,
Jack
- Untitled.png (331.32 KiB) Viewed 23136 times
Hello Jack,
Thanks for the feedback.
Have you tried to change the language in the "Language..." option at design time, in the contextual menu?
How do I change the language ? Remember I can't read Japanese/Korean.
But let's focus on the feature demo. What actions should I take to see the editor in English ?
Greetings,
Jack
Greetings,
Jack
Hello Jack,
In VB6, the "Language..." option is the penultimate in the contextual menu, and "English" is the first language in the list. However, in another IDE, the "Language..." option could be into an "Options" submenu.
Thanks, That did the trick.
But it makes me wonder why TC behaved this way. It never did this before.
Greetings,
Jack
Greetings,
Jack
Hello Jack,
I've tried it in two different machines and I got always the editor in English. So I'm not sure what could cause this in your machine.
Anyway, I'm happy to hear you could change it.
Hello Jack,
We've just uploaded the revised version. Thanks for reporting it.Yeray wrote:That's right. We're investigating what happened here. I'll be back here asap.Jack007 wrote:BTW the OCX (TeeChart2011.ocx) shows under properties, details, file version: 2010.0.0.3 !
You're welcom.
BTW Would it be possible, beside the complete installer, that you also make the revised ocx-file available for distributing maintenance releases?
I remember that you did this with earlier releases of TC.
TIA
Jack
TIA
Jack
Hi Jack,
I just sent you an email with the URL to download latest ocx.
