If the color of the panel is clWhite, this code doesn't work:
ABitmap := Chart.TeeCreateBitmap;
The series is not visible.
This a workaround:
ABitmap := Chart.TeeCreateBitmap(TColor($FEFEFE), Chart.GetRectangle);
This seems to work since TColor($FEFEFE) <> the color of the panel.
How can this be fixed?
TeeChart v2011.03.30407
Delphi XE
Jørgen
TeeCreateBitmap doesn't work if panel color is clWhite
Re: TeeCreateBitmap doesn't work if panel color is clWhite
Hello Jørgen,
I can't see any strange behaviour with the following code in v2011.03, am I missing something?
I see the same behaviour with clWhite and clRed.
uses Chart, ExtCtrls;
var Chart1: TChart;
Image1: TImage;
Chart1:=TChart.Create(self);
Chart1.Parent:=Form1;
Chart1.Color:=clWhite; //clRed;
Image1:=TImage.Create(self);
Image1.Parent:=Form1;
Image1.BoundsRect:=Chart1.BoundsRect;
Image1.Top:=Chart1.Height;
var ABitmap: TBitmap;
ABitmap:=Chart1.TeeCreateBitmap;
Image1.Picture.Bitmap:=ABitmap;
Added a sample that doesn't work
It is something wrong with load from stream
(It works the second time you click)
Jørgen
Jørgen
- Project2.zip
- (84.96 KiB) Downloaded 574 times
Hello Jørgen,
Try forcing a Chart repaint after changing the color:
Chart1.Color := clRed; //works
Chart1.Draw;
It worked.
What is the reason?
Is it a bug?
Jørgen
What is the reason?
Is it a bug?
Jørgen
Hi Jørgen,
This is because TeeCreateBitmap function uses the internal Bitmap already created instead of creating a new one when UseBuffer=true (as per default). So another alternative would be setting it to false:
Chart1.Canvas.UseBuffer:=false;
