Console Application
Console Application
Is it possible to create a graph as an image file in a console application?
Re: Console Application
Hello MikeTheLad,
Yes is possible. You only have added TeeChart.dll and System.Windows.Forms references and then you can do something as next:
Please, can you confirm us if previous code works as you expected?
class Program
static void Main(string[] args)
Steema.TeeChart.TChart tChart1 = new Steema.TeeChart.TChart();
Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
line.FillSampleValues();
tChart1.Export.Image.JPEG.Save(@"C:\tmp\ConsoleImage.jpg");
I get the error below
Error 1 The type 'System.Windows.Forms.Control' is defined in an assembly that is not referenced. You must add a reference to assembly 'System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
I can't add System.Windows.Forms as not on my list
Hello MikeTheLad,
Please follow next steps:
1.- Click with right button on folder of references
2.- Select Add Reference
3.- Select Tab .Net
4.- Find System.Windows.Froms in the list and add it in the project and run it.
Please can you confirm us if using previous steps you can find the reference?
3.- Select Tab .Net
Thanks, I was trying the COM reference, produce a sample graph file now. So I assume now I have all the functions off all graphs available.
How would I go about specifying the size of the graph?
Hi MikeTheLad,
You can either set the chart control dimensions:
Or set the exported image dimensions:
tChart1.Width = 800;
tChart1.Height = 600;
tChart1.Export.Image.JPEG.Width = 800;
tChart1.Export.Image.JPEG.Height = 600;
Have sorted the sizing
This is all working fine in Visual 2010, I am now trying in a Visual 2008 application to do the same, on the line
This is falling over with "Object reference not set to an instance of an object.", all the dll are in place and registered as per the 2010 app
Hi MikeTheLad,
This error message indicates that your application doesn't have the design-time license properly compiled into it as I explained here.
I did see this thread before and belive this is the problem however this is for V2, we have V1
Also, this solution does have a website and the graph works fine in this
Hi MikeTheLad,
If problems persist please attach a simple example project we can run "as-is" to reproduce the problem here.
I think this also applies to later v1 releases.I did see this thread before and belive this is the problem however this is for V2, we have V1
The web application could be set up correctly but not the console application. Could you please check it has licenses.licx compiled as an embedded resource?Also, this solution does have a website and the graph works fine in this
That was it, I added that file to the project and can now create graphs, however I only getting one bar per series, code is:-
Steema.TeeChart.Styles.Bar bar2 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
tChart1.Header.Text = "";
tChart1.Chart.Panel.Color = System.Drawing.Color.White;
tChart1.Chart.Panel.Visible = false;
tChart1.Chart.Walls.Visible = false;
tChart1.Chart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
tChart1.Chart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
tChart1.Axes.Bottom.Title.Visible = true;
tChart1.Axes.Bottom.Title.Text = "Age";
tChart1.Axes.Left.Title.Visible = true;
tChart1.Axes.Left.Title.Text = "Frequency";
bar1.Add(300, "Jan");
bar1.Add(325, "Feb");
bar1.Add(287, "Mar");
bar1.Title = "Product10";
bar2.Add(175, "Jan");
bar2.Add(223, "Feb");
bar2.Add(241, "Mar");
bar2.Title = "Product12";
- RAL_488_AgeGraph.jpg (84.04 KiB) Viewed 20054 times
Hi MikeTheLad,
That's because you set bottom axis to be manual. You can either remove this line:
Or set its min. and max. values manually like this:
tChart1.Axes.Bottom.SetMinMax(0, 2);
