Console Application
MikeTheLad
Console Application
Post by MikeTheLad » Thu Jul 14, 2011 7:53 am
Is it possible to create a graph as an image file in a console application?
Re: Console Application
Post by Sandra » Thu Jul 14, 2011 2:32 pm
Hello MikeTheLad,
Yes is possible. You only have added TeeChart.dll and System.Windows.Forms references and then you can do something as next:
   class Program
        static void Main(string[] args)
            Steema.TeeChart.TChart tChart1 = new Steema.TeeChart.TChart();
            Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            line.FillSampleValues();
            tChart1.Export.Image.JPEG.Save(@"C:\tmp\ConsoleImage.jpg");
Please, can you confirm us if previous code works as you expected?
MikeTheLad
Post by MikeTheLad » Thu Jul 14, 2011 3:31 pm
I get the error below
Error 1 The type 'System.Windows.Forms.Control' is defined in an assembly that is not referenced. You must add a reference to assembly 'System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
I can't add System.Windows.Forms as not on my list
Post by Sandra » Thu Jul 14, 2011 4:06 pm
Hello MikeTheLad,
Please follow next steps:
1.- Click with right button on folder of references
2.- Select Add Reference
3.- Select Tab .Net
4.- Find System.Windows.Froms in the list and add it in the project and run it.
Please can you confirm us if using previous steps you can find the reference?
MikeTheLad
Post by MikeTheLad » Thu Jul 14, 2011 4:23 pm
Thanks, I was trying the COM reference, produce a sample graph file now. So I assume now I have all the functions off all graphs available.
MikeTheLad
Post by MikeTheLad » Thu Jul 14, 2011 4:29 pm
How would I go about specifying the size of the graph?
Post by Narcís » Fri Jul 15, 2011 7:45 am
Hi MikeTheLad,
You can either set the chart control dimensions:
      tChart1.Width = 800;
      tChart1.Height = 600;
Or set the exported image dimensions:
      tChart1.Export.Image.JPEG.Width = 800;
      tChart1.Export.Image.JPEG.Height = 600;
MikeTheLad
Post by MikeTheLad » Fri Jul 15, 2011 8:03 am
Have sorted the sizing
MikeTheLad
Post by MikeTheLad » Mon Sep 26, 2011 10:40 am
This is all working fine in Visual 2010, I am now trying in a Visual 2008 application to do the same, on the line
This is falling over with "Object reference not set to an instance of an object.", all the dll are in place and registered as per the 2010 app
Post by Narcís » Mon Sep 26, 2011 10:56 am
Hi MikeTheLad,
This error message indicates that your application doesn't have the design-time license properly compiled into it as I explained here.
MikeTheLad
Post by MikeTheLad » Mon Sep 26, 2011 11:03 am
I did see this thread before and belive this is the problem however this is for V2, we have V1
MikeTheLad
Post by MikeTheLad » Mon Sep 26, 2011 11:04 am
Also, this solution does have a website and the graph works fine in this
Post by Narcís » Mon Sep 26, 2011 1:28 pm
Hi MikeTheLad,
I think this also applies to later v1 releases.
The web application could be set up correctly but not the console application. Could you please check it has licenses.licx compiled as an embedded resource?
If problems persist please attach a simple example project we can run "as-is" to reproduce the problem here.
MikeTheLad
Post by MikeTheLad » Mon Sep 26, 2011 1:58 pm
That was it, I added that file to the project and can now create graphs, however I only getting one bar per series, code is:-
Steema.TeeChart.Styles.Bar bar2 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
tChart1.Header.Text = "";
tChart1.Chart.Panel.Color = System.Drawing.Color.White;
tChart1.Chart.Panel.Visible = false;
tChart1.Chart.Walls.Visible = false;
tChart1.Chart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
tChart1.Chart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
tChart1.Axes.Bottom.Title.Visible = true;
tChart1.Axes.Bottom.Title.Text = "Age";
tChart1.Axes.Left.Title.Visible = true;
tChart1.Axes.Left.Title.Text = "Frequency";
bar1.Add(300, "Jan");
bar1.Add(325, "Feb");
bar1.Add(287, "Mar");
bar1.Title = "Product10";
bar2.Add(175, "Jan");
bar2.Add(223, "Feb");
bar2.Add(241, "Mar");
bar2.Title = "Product12";
Post by Narcís » Mon Sep 26, 2011 2:49 pm
Hi MikeTheLad,
That's because you set bottom axis to be manual. You can either remove this line:
Or set its min. and max. values manually like this:
      tChart1.Axes.Bottom.SetMinMax(0, 2);
