I am using Delphi 2007 and recently did some testing with new TeeChart 2010 but went back because of a bug that needs to be fixed first (TV52015430).
Now I have a design-time problem. Take a look at the images and see what happens: a TBarSeries is added to the chart and the form is saved.
On reopening the BarSeries is no longer visible, only as a square in the upper left corner of the form.
Something goes wrong when loading the form. If I don't open the form, I am able to recompile the unit.
Does anyone recognize this? Any suggestion is welcome.
Bert
Series get lost during designtime
Re: Series get lost during designtime
Hello Bert,
I've tried to reproduce it in a new simple application but I can't. I've only added a Chart to the form and a Bar Series to the Chart. I've saved the application, closed it and reopened. The Chart and the Bar Series are shown without problems for me here.
Could you please check the application attached?
- Bartest.zip
- (1.35 KiB) Downloaded 677 times
Thanks for your help. Your attachment has the same problem here.
Something must have gone wrong with my setup of TeeChart. It is definitely my fault.
I guess there is no use in trying to reproduce, because you can't, unless the installation is messed up.
Now I am waiting for someone who recognizes the problem and can tell the solution.
Bert
Bert
Hi Bert,
It's also worth mentioning that TV52015430 has been fixed for the next maintenance release which we expect to publish at the beginning of next week. You might want to wait for that and check if it solves those issues at your end.
