guilz2010
Post
by guilz2010 » Thu Mar 24, 2011 4:20 pm
I would like to draw lines on teechart and with a command, duplicate selected line and link it to parent. So after that when I move the first line, the second is moved too (like with horizontal or vertical parallel style)
How can I do that ?
In the code bellow I write the duplicate line function but lines are not linked between them so when I move the first one, the second one does not move
Private Sub Command1_Click()
Dim currentLineIndex As Integer
TChart1.Tools.Items(0).asDrawLine.SelectNewLines = True
currentLineIndex = TChart1.Tools.Items(0).asDrawLine.Selected
Dim oLine As IDrawLine
Set oLine = TChart1.Tools.Items(0).asDrawLine.Lines.Items(currentLineIndex)
With oLine
Call TChart1.Tools.Items(0).asDrawLine.AddLine(.StartPos.X, .StartPos.Y - 100, .EndPos.X, .EndPos.Y - 100)
End With
Dim nLine As IDrawLine
Set nLine = TChart1.Tools.Items(0).asDrawLine.Lines.Items(currentLineIndex + 1)
With nLine
.Pen.Color = oLine.Pen.Color
.Pen.Style = oLine.Pen.Style
End With
2)
I would like to rotate selected lines with mouse. How can I do that ?
Thanks a lot for your help
Kind regards,
Guilz
ps : I use Teechart v8
(because v2010 is not very stable actually
Post
by Yeray » Mon Mar 28, 2011 11:23 am
Hello Guilz,
Using the v2010, the code bellow drags the drawn lines correctly.
Could you please check it for you?
Dim oLine, nLine As IDrawLine
Private Sub Form_Load()
TChart1.Aspect.View3D = False
TChart1.AddSeries scLine
TChart1.Tools.Add tcDrawLine
Private Sub TChart1_OnDrawLineToolLineDrag()
If currentLineIndex > -1 Then
If currentLineIndex Mod 2 Then
Set nLine = TChart1.Tools.Items(0).asDrawLine.Lines.Items(currentLineIndex - 1)
nLine.StartPos.Y = oLine.StartPos.Y + 100
nLine.EndPos.Y = oLine.EndPos.Y + 100
Else
nLine.StartPos.Y = oLine.StartPos.Y - 100
nLine.EndPos.Y = oLine.EndPos.Y - 100
End If
nLine.StartPos.X = oLine.StartPos.X
nLine.EndPos.X = oLine.EndPos.X
TChart1.Repaint
End If
Private Sub TChart1_OnDrawLineToolNewLine()
With oLine
TChart1.Tools.Items(0).asDrawLine.AddLine .StartPos.X, .StartPos.Y - 100, .EndPos.X, .EndPos.Y - 100
End With
With nLine
End With
oLine.Pen.Style = psNothing
oLine.Pen.Style = psSolid
If it works fine, you should do something similar to implement a rotation.
guilz2010
Post
by guilz2010 » Mon Mar 28, 2011 12:20 pm
Hello Yeray,
Thanks for your answer, it's working pretty well
I have an issue now with the Axis Scroll tools with your code: when I try to move the bottom axis, a new line is drawn !
So I can't move the chart with the Axis Scroll tools...
How can I fix it ?
King Regards,
Guilz
guilz2010
Post
by guilz2010 » Mon Mar 28, 2011 1:02 pm
The 2nd thing is I would like to move only 1 line when I press ctrl button.
How can I do that Yeray ?
Thank you
Guilz
Post
by Yeray » Wed Mar 30, 2011 7:52 am
Hello Guilz,
The easiest would probably be to use the Key events to activate/deactivate the EnableDraw and EnableSelect properties:
TChart1.Tools.Items(0).asDrawLine.EnableDraw = False
TChart1.Tools.Items(0).asDrawLine.EnableSelect = False
Else
End If
TChart1.Repaint
End If
With oLine
End With
With nLine
End With
Private Sub TChart1_OnKeyDown(ByVal KeyCode As Long, ByVal Shift As TeeChart.EShiftState)
If KeyCode = KeyCodeConstants.vbKeyShift Then
TChart1.Tools.Items(0).asDrawLine.EnableDraw = True
TChart1.Cursor = -3
End If
If KeyCode = KeyCodeConstants.vbKeyControl Then
TChart1.Tools.Items(0).asDrawLine.EnableSelect = True
End If
Private Sub TChart1_OnKeyUp(ByVal KeyCode As Long, ByVal Shift As TeeChart.EShiftState)
TChart1.Cursor = -2
End If
End If
guilz2010
Post
by guilz2010 » Thu Mar 31, 2011 12:53 pm
It's not good for me but it's probably beacause i'm not clear
My need: be able to select and move only 1 line
when ctrl key is down only. In your code when i move 1 line the second one is moved too.
This need is to change the distance between 2 lines pressing ctrl key and moving 1 line...
- line.png (36.55 KiB) Viewed 16645 times
Kind Regards Yeray
Guilz
Post
by Yeray » Fri Apr 01, 2011 8:01 am
Hi Guilz,
Ok, Ctrl key to move up/down each line individually. Playing a little bit with the last code it could be possible:
ForceLine
With oLine
End With
With nLine
End With
TChart1.Cursor = -3
End If
End If
TChart1.Cursor = -2
End If
End If
Private Sub TChart1_OnMouseMove(ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
ForceLine
Private Sub ForceLine()
Else
End If
oLine.StartPos.X = nLine.StartPos.X
oLine.EndPos.X = nLine.EndPos.X
TChart1.Repaint
End If
The result isn't perfect. The dragged line is shown in it's temporal location and redrawn in its forced final location giving a flickering result.
I don't see how to avoid this easily. However, an option would probably be to hide the dragged line and use custom drawing techniques to draw the final location while dragging.
guilz2010
Post
by guilz2010 » Fri Apr 01, 2011 8:27 am
Thank you to try to find a solution - I can't use your code because it is not working well for me (flickering, can't move the 2 lines at the same time when ctrl key is not pressed...)
Kind regards,
Guilz
Post
by Narcís » Fri Apr 01, 2011 11:27 am
Hi Guilz,
I'm taking up on this and I may be missing something but what about doing something like this? When selecting a line you can either drag or modify it. My suggestion is simpler than what was discussed here. If it doesn't fit your needs please let me know what's missing.
TChart1.Tools.Items(0).asDrawLine.EnableSelect = (Shift = ssCtrl)
guilz2010
Post
by guilz2010 » Fri Apr 01, 2011 11:40 am
Hi Narcis,
Thanks for your contribution but It does not respond to my need (be able, when I draw 1 line to draw a second line automaticaly and after, when I move 1 line the second line is moved too and third, when I press ctrl key and clic on 1 line, only this line is moved (to change the distance between line A and B)
Please try the code I made, it's working pretty well now...Perhaps we can optimize it...
Guilz
Dim CTRL_KEY_DOWN As Boolean
Dim dicHeight As New Scripting.Dictionary
Const DEFAULT_HEIGHT As Long = 100
currentLineIndex = TChart1.Tools.Items(1).asDrawLine.Selected
Set oLine = TChart1.Tools.Items(1).asDrawLine.Lines.Items(currentLineIndex)
If CTRL_KEY_DOWN = True Then
Debug.Print ""
' Deplacement d'1 seule ligne
Else
Dim H As Long
If dicHeight.Exists(currentLineIndex) Then
H = dicHeight.Item(currentLineIndex)
Else
H = DEFAULT_HEIGHT
End If
' Nouvelle ligne
Set nLine = TChart1.Tools.Items(1).asDrawLine.Lines.Items(currentLineIndex - 1)
nLine.StartPos.Y = oLine.StartPos.Y + H
nLine.EndPos.Y = oLine.EndPos.Y + H
Else
Set nLine = TChart1.Tools.Items(1).asDrawLine.Lines.Items(currentLineIndex + 1)
nLine.StartPos.Y = oLine.StartPos.Y - H
nLine.EndPos.Y = oLine.EndPos.Y - H
End If
TChart1.Repaint
End If
End If
Dim H As Long
TChart1.Tools.Items(1).asDrawLine.SelectNewLines = True
With oLine
H = DEFAULT_HEIGHT
TChart1.Tools.Items(1).asDrawLine.AddLine .StartPos.X, .StartPos.Y - H, .EndPos.X, .EndPos.Y - H
If dicHeight.Exists(currentLineIndex) = False Then
dicHeight.Add currentLineIndex, H
dicHeight.Add currentLineIndex + 1, -H
End If
End With
With nLine
End With
Debug.Print "down " & KeyCode, Shift
If KeyCode = 17 And Shift = 4 Then CTRL_KEY_DOWN = True
Debug.Print "up " & KeyCode, Shift
If KeyCode = 17 And Shift = 0 Then
Dim H As Long
H = nLine.EndPos.Y - oLine.EndPos.Y
dicHeight.Remove (currentLineIndex)
dicHeight.Remove (currentLineIndex - 1)
dicHeight.Add currentLineIndex - 1, -H
End If
Else
H = oLine.EndPos.Y - nLine.EndPos.Y
dicHeight.Remove (currentLineIndex + 1)
End If
End If
End If
CTRL_KEY_DOWN = False
End If
Post
by Yeray » Mon Apr 04, 2011 10:43 am
Hello Guilz,
So this is working as you would like, isn't it? If not, please, try to explain us what aspect would you exactly want to optimize.
