Drawing lines and link them for moving and rotating
guilz2010
Post by guilz2010 » Thu Mar 24, 2011 4:20 pm
I would like to draw lines on teechart and with a command, duplicate selected line and link it to parent. So after that when I move the first line, the second is moved too (like with horizontal or vertical parallel style)
How can I do that ?
In the code bellow I write the duplicate line function but lines are not linked between them so when I move the first one, the second one does not move :oops:
Private Sub Command1_Click()
    Dim currentLineIndex As Integer
    TChart1.Tools.Items(0).asDrawLine.SelectNewLines = True
    currentLineIndex = TChart1.Tools.Items(0).asDrawLine.Selected
    Dim oLine As IDrawLine
    Set oLine = TChart1.Tools.Items(0).asDrawLine.Lines.Items(currentLineIndex)
    With oLine
        Call TChart1.Tools.Items(0).asDrawLine.AddLine(.StartPos.X, .StartPos.Y - 100, .EndPos.X, .EndPos.Y - 100)
    End With
    Dim nLine As IDrawLine
    Set nLine = TChart1.Tools.Items(0).asDrawLine.Lines.Items(currentLineIndex + 1)
    With nLine
        .Pen.Color = oLine.Pen.Color
        .Pen.Style = oLine.Pen.Style
    End With
2)
I would like to rotate selected lines with mouse. How can I do that ?
Thanks a lot for your help :D
Kind regards,
Guilz
ps : I use Teechart v8 (because v2010 is not very stable actually :D )
Re: Drawing lines and link them for moving and rotating
Post by Yeray » Mon Mar 28, 2011 11:23 am
Hello Guilz,
Using the v2010, the code bellow drags the drawn lines correctly.
Could you please check it for you?
Dim oLine, nLine As IDrawLine
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scLine
  TChart1.Tools.Add tcDrawLine
Private Sub TChart1_OnDrawLineToolLineDrag()
  If currentLineIndex > -1 Then
    If currentLineIndex Mod 2 Then
      Set nLine = TChart1.Tools.Items(0).asDrawLine.Lines.Items(currentLineIndex - 1)
      nLine.StartPos.Y = oLine.StartPos.Y + 100
      nLine.EndPos.Y = oLine.EndPos.Y + 100
    Else
      nLine.StartPos.Y = oLine.StartPos.Y - 100
      nLine.EndPos.Y = oLine.EndPos.Y - 100
    End If
    nLine.StartPos.X = oLine.StartPos.X
    nLine.EndPos.X = oLine.EndPos.X
    TChart1.Repaint
  End If
Private Sub TChart1_OnDrawLineToolNewLine()
    With oLine
        TChart1.Tools.Items(0).asDrawLine.AddLine .StartPos.X, .StartPos.Y - 100, .EndPos.X, .EndPos.Y - 100
    End With
    With nLine
    End With
    oLine.Pen.Style = psNothing
    oLine.Pen.Style = psSolid
If it works fine, you should do something similar to implement a rotation.
guilz2010
Post by guilz2010 » Mon Mar 28, 2011 12:20 pm
Hello Yeray,
Thanks for your answer, it's working pretty well :D
I have an issue now with the Axis Scroll tools with your code: when I try to move the bottom axis, a new line is drawn !
So I can't move the chart with the Axis Scroll tools...
How can I fix it ?
King Regards,
Guilz
guilz2010
Post by guilz2010 » Mon Mar 28, 2011 1:02 pm
The 2nd thing is I would like to move only 1 line when I press ctrl button.
How can I do that Yeray ?
Thank you
Guilz
Post by Yeray » Wed Mar 30, 2011 7:52 am
Hello Guilz,
The easiest would probably be to use the Key events to activate/deactivate the EnableDraw and EnableSelect properties:
  TChart1.Tools.Items(0).asDrawLine.EnableDraw = False
  TChart1.Tools.Items(0).asDrawLine.EnableSelect = False
    Else
    End If
    TChart1.Repaint
  End If
    With oLine
    End With
    With nLine
    End With
Private Sub TChart1_OnKeyDown(ByVal KeyCode As Long, ByVal Shift As TeeChart.EShiftState)
  If KeyCode = KeyCodeConstants.vbKeyShift Then
    TChart1.Tools.Items(0).asDrawLine.EnableDraw = True
    TChart1.Cursor = -3
  End If
  If KeyCode = KeyCodeConstants.vbKeyControl Then
    TChart1.Tools.Items(0).asDrawLine.EnableSelect = True
  End If
Private Sub TChart1_OnKeyUp(ByVal KeyCode As Long, ByVal Shift As TeeChart.EShiftState)
    TChart1.Cursor = -2
  End If
  End If
guilz2010
Post by guilz2010 » Thu Mar 31, 2011 12:53 pm
It's not good for me but it's probably beacause i'm not clear :D
My need: be able to select and move only 1 line when ctrl key is down only. In your code when i move 1 line the second one is moved too.
This need is to change the distance between 2 lines pressing ctrl key and moving 1 line...
Kind Regards Yeray
Guilz
Post by Yeray » Fri Apr 01, 2011 8:01 am
Hi Guilz,
Ok, Ctrl key to move up/down each line individually. Playing a little bit with the last code it could be possible:
  ForceLine
    With oLine
    End With
    With nLine
    End With
    TChart1.Cursor = -3
  End If
  End If
    TChart1.Cursor = -2
  End If
  End If
Private Sub TChart1_OnMouseMove(ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
  ForceLine
Private Sub ForceLine()
    Else
    End If
    oLine.StartPos.X = nLine.StartPos.X
    oLine.EndPos.X = nLine.EndPos.X
    TChart1.Repaint
  End If
The result isn't perfect. The dragged line is shown in it's temporal location and redrawn in its forced final location giving a flickering result.
I don't see how to avoid this easily. However, an option would probably be to hide the dragged line and use custom drawing techniques to draw the final location while dragging.
guilz2010
Post by guilz2010 » Fri Apr 01, 2011 8:27 am
Thank you to try to find a solution - I can't use your code because it is not working well for me (flickering, can't move the 2 lines at the same time when ctrl key is not pressed...)
Kind regards,
Guilz
Post by Narcís » Fri Apr 01, 2011 11:27 am
Hi Guilz,
I'm taking up on this and I may be missing something but what about doing something like this? When selecting a line you can either drag or modify it. My suggestion is simpler than what was discussed here. If it doesn't fit your needs please let me know what's missing.
    TChart1.Tools.Items(0).asDrawLine.EnableSelect = (Shift = ssCtrl)
guilz2010
Post by guilz2010 » Fri Apr 01, 2011 11:40 am
Hi Narcis,
Thanks for your contribution but It does not respond to my need (be able, when I draw 1 line to draw a second line automaticaly and after, when I move 1 line the second line is moved too and third, when I press ctrl key and clic on 1 line, only this line is moved (to change the distance between line A and B)
Please try the code I made, it's working pretty well now...Perhaps we can optimize it...
Guilz
    Dim CTRL_KEY_DOWN As Boolean
    Dim dicHeight As New Scripting.Dictionary
    Const DEFAULT_HEIGHT As Long = 100
      currentLineIndex = TChart1.Tools.Items(1).asDrawLine.Selected
        Set oLine = TChart1.Tools.Items(1).asDrawLine.Lines.Items(currentLineIndex)
        If CTRL_KEY_DOWN = True Then
            Debug.Print ""
            ' Deplacement d'1 seule ligne
        Else
             Dim H As Long
             If dicHeight.Exists(currentLineIndex) Then
                H = dicHeight.Item(currentLineIndex)
             Else
                H = DEFAULT_HEIGHT
             End If
             ' Nouvelle ligne
               Set nLine = TChart1.Tools.Items(1).asDrawLine.Lines.Items(currentLineIndex - 1)
               nLine.StartPos.Y = oLine.StartPos.Y + H
               nLine.EndPos.Y = oLine.EndPos.Y + H
             Else
               Set nLine = TChart1.Tools.Items(1).asDrawLine.Lines.Items(currentLineIndex + 1)
               nLine.StartPos.Y = oLine.StartPos.Y - H
               nLine.EndPos.Y = oLine.EndPos.Y - H
             End If
             TChart1.Repaint
        End If
      End If
        Dim H As Long
        TChart1.Tools.Items(1).asDrawLine.SelectNewLines = True
        With oLine
            H = DEFAULT_HEIGHT
            TChart1.Tools.Items(1).asDrawLine.AddLine .StartPos.X, .StartPos.Y - H, .EndPos.X, .EndPos.Y - H
             If dicHeight.Exists(currentLineIndex) = False Then
                dicHeight.Add currentLineIndex, H
                dicHeight.Add currentLineIndex + 1, -H
             End If
        End With
        With nLine
        End With
    Debug.Print "down " & KeyCode, Shift
    If KeyCode = 17 And Shift = 4 Then CTRL_KEY_DOWN = True
    Debug.Print "up " & KeyCode, Shift
    If KeyCode = 17 And Shift = 0 Then
         Dim H As Long
           H = nLine.EndPos.Y - oLine.EndPos.Y
               dicHeight.Remove (currentLineIndex)
               dicHeight.Remove (currentLineIndex - 1)
               dicHeight.Add currentLineIndex - 1, -H
            End If
         Else
            H = oLine.EndPos.Y - nLine.EndPos.Y
               dicHeight.Remove (currentLineIndex + 1)
            End If
         End If
      End If
    CTRL_KEY_DOWN = False
    End If
Post by Yeray » Mon Apr 04, 2011 10:43 am
Hello Guilz,
So this is working as you would like, isn't it? If not, please, try to explain us what aspect would you exactly want to optimize.
