Evaluation
Dmitry
Evaluation
Post by Dmitry » Mon Feb 21, 2011 5:06 pm
I have downloaded last version teechart for java. But It's evaluation version. Why? Previous version was correctly
Re: Evaluation
Post by Yeray » Wed Feb 23, 2011 3:46 pm
Hi Dimitry,
Are you sure you haven't installed the evaluation version? Once you've verified you've installed the registered version, you only should check that your project uses the correct .jar.
Dmitry
Re: Evaluation
Post by Dmitry » Sat Feb 26, 2011 10:01 am
I downloaded from customer's zone and activated copy. After I copied TeeChart.SWT.jar to my library path, old jar was removed.
Where can I get correct.jar?
Re: Evaluation
Post by Yeray » Tue Mar 01, 2011 10:52 am
Hi Dimitry,
I still think it has to be something with the paths, somehow. What IDE are you using?
Here, I've just downloaded both the Evaluation (TeeChartJava2Evaluation.zip) and the Pro version (TeeChartJava2_with_Sources.zip) and I can show/hide the EVALUATION text simply changing the order of the paths in a NetBeans application:
The test application only creates a Bar series and fills it with some sample values.
Dmitry
Re: Evaluation
Post by Dmitry » Tue Mar 01, 2011 7:36 pm
My screenshot is evidence too and I downloaded TeeChartJava2_with_Sources.zip. I use Eclipse (Helios).
Previous version is correctly
Re: Evaluation
Post by Yeray » Thu Mar 03, 2011 3:57 pm
Hi Dimitry,
The question is that, as you'll understand, we need to reproduce the problems here in a solid way so we can study why it is happening.
In Eclipse Helios and the following application I see this:
test.zip
(1.81 MiB) Downloaded 1244 times
In the case of Eclipse, I've seen that having both the eval and the Pro .jar in the list (ordered with your preference) doesn't seem to be enough and the "evaluation" text is always shown. So I have to remove the eval .jar from the library list to show the chart without the text.
Could you please check it.
Dmitry
Re: Evaluation
Post by Dmitry » Thu Mar 17, 2011 9:19 am
Yeray, I'm using SWT version. Your examples with Swing
Re: Evaluation
Post by Yeray » Fri Mar 18, 2011 12:06 pm
Hi Dimitry,
Ok. You are right. It seems that the TeeChart.SWT.jar uses the wrong ERMode.java. We'll try to fix it asap (TJ71015452).
However, I can link the SWT sources instead of the jar and it works fine. If you have problems with it, don't hesitate to let us know.
Dmitry
Re: Evaluation
Post by Dmitry » Sun Apr 24, 2011 6:33 pm
AND where is new fix?
Dmitry
Re: Evaluation
Post by Narcís » Tue Apr 26, 2011 10:46 am
Hi Dmitry,
No TeeChart for Java release has been published since you reported this issue. I recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's implemented on them.
