johnnix
- Advanced
Post
by johnnix » Mon Feb 07, 2011 6:30 am
Hello Steema Team,
I really believe that your component is top class but you really have issues with your updates. Actually I am having the idea that you are not updating in the traditional way of "adding" new features or "fixing" bugs, you completely alter the behavior of several functions. I will not get into details as there are a lot of things not working properly for my app using your latest 2010 update e.g. the following code does not work any more with TLineSeries:
procedure TMyProject.ApplyPlotLineColor(aChart: TChart);
if aChart.SeriesCount > 0 then
aChart.Series[0].Pen.Color := PlotLineColor;
Post
by Narcís » Mon Feb 07, 2011 8:15 am
Hi johnnix,
If you look at the
release notes you'll see we have fixed some bugs in this area. In 2D you have to use series Color as shown in the code snippet below.
uses Series;
Chart1.View3D:=False;
Chart1.AddSeries(TLineSeries.Create(Self)).FillSampleValues;
if Chart1.SeriesCount > 0 then
Chart1[0].Color := clLime;
If you think there are other issues not working how they should please don't hesitate to let us know. We will try to help you finding out how to use them or address them.
johnnix
- Advanced
Post
by johnnix » Mon Feb 07, 2011 11:03 am
Thank you for the prompt reply.
1. Release notes refer to a 2D color bug fix which is so general that I could not imagine that my code is no longer valid
2. I am using the following code to place a TChart inside a custom metafile in a certain position. This code now puts the chart way off the provided coordinates:
MyChart.CustomChartRect := true;
MyChart.ChartRect:=TeeRect(30, start_y, 150,
start_y+trunc(total_depth*(h-start_y)/total_depth));
Mychart.DrawToMetaCanvas(canvas, Mychart.ChartRect);
Post
by Yeray » Thu Feb 10, 2011 4:15 pm
Hi johnnix,
johnnix wrote:1. Release notes refer to a 2D color bug fix which is so general that I could not imagine that my code is no longer valid
Looking into the forums I've found the thread where the bug
TV52015199 was reported. And
TV52014124, that is related to it.
Note that in the release notes we try to resume the bugs in a few words. You can always search for the origin of the tickets or ask us directly, here in the forums.
johnnix wrote:2. I am using the following code to place a TChart inside a custom metafile in a certain position. This code now puts the chart way off the provided coordinates:
We've modified the CustomChartRect behaviour some time ago. Now it calculates the space to place the labels and the axes. Maybe that's the reason why it is not drawn where you expected.
If you can arrange a simple example project we can run as-is to reproduce the problem here, we'll be pleased to take a look at it and try to explain how you could make it look better, if possible.
johnnix
- Advanced
Post
by johnnix » Fri Feb 11, 2011 5:59 am
There is no need to create an example, I will just need information on how to use the function so that I could draw the plot in such a way where the top left point of the Y axis is placed on the point coordinates I provide.
Post
by Yeray » Mon Feb 14, 2011 2:07 pm
Hi johnnix,
I reproduced the problem with the attached project. So I've added it to the defect list to be fixed in future releases (TV52015390).
It seems that the fix for the bug TV52015163 has broken it. If you are a source code customer, you could search for "TV52015163" into TeeProcs.pas and revert the fix for it. Concretely removing/commenting the line:
OffsetRect(ChartRect,FChartBounds.Left,FChartBounds.Top);
Post
by Yeray » Mon Feb 21, 2011 8:58 am
Hi johnnix,
Adding a little condition to the mentioned line in TeeProcs.pas solves both problems. So the following will be in the next maintenance release:
if FPrinting then OffsetRect(ChartRect,FChartBounds.Left,FChartBounds.Top);
You could try it in the sources you have.
