TLineSeries with TeeChart2010
FredrikOstlund
Post by FredrikOstlund » Sat Feb 05, 2011 6:03 pm
I have serious problems with the TLineSeries in the new TeeChart for VCL. Using AddXY to add a point does not work properly. The following code snippet shows an empty plot:
void __fastcall TForm1::FormCreate(TObject *Sender) {
for (double i = 0; i < 10; i++) {
Series1->AddXY(2 * i, i);
Furthermore, the following snipper raises an EAccessException.
Series1->Clear();
As does the following:
Series1->FillSampleValues(100);
double max = Series1->MaxYValue();
Is the TLineSeries completely broken, or am I doing something wrong? I'm using TeeChart 2010, C++ builder XE and Windows Vista.
best regards
Fredrik Östlund
FredrikOstlund
Re: TLineSeries with TeeChart2010
Post by FredrikOstlund » Sun Feb 06, 2011 11:20 am
Hi again,
an update:
I found the AddXY not working under c++ is already known:
http://www.teechart.net/support/viewtop ... dxy#p51484
However, the fix given there does not work either.
Also, the following functions raises exceptions:
* Series1->Color = clRed;
* Chart1->Title->Caption = "asfsdf";
* Chart1->Title->Color = clRed;
Does not raise exception, but does not do anything:
Series1->SeriesColor = clRed;
I did not test systematically, but it seems a whole lot is not working. A bit too much even, which makes me suspect that there is something wrong with my setup. Could anyone test if the given code works? If there is a problem with TeeChart 2010, is there any way of getting an older version?
best regards
Fredrik Östlund
FredrikOstlund
Post by FredrikOstlund » Sun Feb 06, 2011 11:22 am
Oh, I'm using the latest (Feb 2011) Pro version of TeeChart.
FredrikOstlund
Post by FredrikOstlund » Sun Feb 06, 2011 6:18 pm
Found the problem. Include files had to go at the top in c++ builder.
Post by Yeray » Mon Feb 07, 2011 6:22 pm
Hi Fredrik,
I'm glad to hear you've found it.
