Wrong alignment at the first and last stacked bar
Josef Schliffenbacher
Post by Josef Schliffenbacher » Sat Dec 11, 2010 12:14 pm
I changed the TeeChart Version 8.02 to 8.07. The result was, that the first and last stacked Bar are shown with approximately the half width. There is no distance to the y-axis.
The PDF-document shows the different. Page 1 is version 8.02 and page 2 is version 8.07. There are no changes made in my source-code.
What I have to do to get the behavior like in Version 8.02?
Thank you for your help.
With kind regards.
Josef.
Version 8.02 and 8.07.zip
(33.84 KiB) Downloaded 285 times
Re: Wrong alignment at the first and last stacked bar
Post by Yeray » Tue Dec 14, 2010 12:39 pm
Hi Josef,
It could be the same that was discussed here
In your case, you could probably solve it adding some offset. For example:
  Chart1.Axes.Bottom.MinimumOffset:=60;
  Chart1.Axes.Bottom.MaximumOffset:=60;
