Access violation when clicking the Drag Point tool in the Te
ChartIt
Post by ChartIt » Fri Dec 10, 2010 4:26 am
I get an Access violation when clicking the Drag Point tool in the TeeChart 2010 demo.
Just for your information.
Access violation when clicking Drag Point.JPG (152.1 KiB) Viewed 11492 times
Bert B.
Re: Access violation when clicking the Drag Point tool in the Te
Post by Bert B. » Fri Dec 10, 2010 11:21 am
Hi ChartIt,
I cannot reproduce it, but there is another error in this demo.
When I click the line between point 2 and 3, it selects point 1.
This is consistent for all lines: cliking the line between point x and x + 1, selects point x - 1.
Bert
Post by Narcís » Fri Dec 10, 2010 11:55 am
Hello everyone,
I can't reproduce any of those here using our current sources. Code snippet below works fine for me here. Can you please check if it works fine at your end? Can you modify it so that we can reproduce the issue here? If you are TeeChart 2010 VCL source code customers I could provide our latest sources for you to test.
uses Series;
var Series1: TLineSeries;
  Series1:=TLineSeries.Create(Self);
  Series1.FillSampleValues;
  Series1.Pointer.Visible:=True;
  Chart1.AddSeries(Series1);
procedure TForm1.Chart1MouseMove(Sender: TObject; Shift: TShiftState; X,
  Y: Integer);
  Caption:=IntToStr(Chart1[0].Clicked(X,Y));
Bert B.
Post by Bert B. » Mon Dec 13, 2010 10:09 am
Hi Narcís,
Did you check this
This is consistent for all lines: clicking the line between point x and x + 1, selects point x - 1.
with the demo application on the website? Maybe it's time to update it.
Bert
Post by Yeray » Wed Dec 15, 2010 1:58 pm
We've updated the compiled features demo here recently. I can't reproduce the error in the first post and neither the problem with the indexes.
Could you please confirm it?
Bert B.
Post by Bert B. » Wed Dec 15, 2010 2:09 pm
My issue has been solved in the new demo, but you might update the text on the website:
TeeChart compiled demo
version : 2010 / date: June 01, 2010
Bert
Post by Narcís » Wed Dec 15, 2010 2:17 pm
Hi Bert,
Thanks for pointing this out. I have updated it to 17th November 2010 which was the date when I posted the current demo.
