I use the latest build of 2010 version. I have a bar chart with THorizBarSeries and bar width set to 60%. What exactly is the bar width and how is it calculated because the bars have a constant width regardless the left axis minimum, maximum so many time get overlapped. How can I make sure that my bars never get overlapped?
Overlapping Bars
Overlapping Bars
- Untitled-1.gif (2.3 KiB) Viewed 4873 times
Re: Overlapping Bars
Hi johnnix,
This may depend on the Y values (or X values with vertical bars) you supply to your bar series. Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
