Legend Position
TestAlways
Legend Position
Post by TestAlways » Tue Nov 30, 2010 2:06 pm
I need the legend to be to the right of the chart, but I want it to be aligned to the bottom rather than the top of the chart.
How can I do that?
Ed Dressel
Re: Legend Position
Post by Yeray » Tue Nov 30, 2010 4:12 pm
Hi Ed,
You could place your legend manually like following:
uses series;
var i: Integer;
  for i:=0 to 4 do
    with Chart1.AddSeries(TBarSeries) do FillSampleValues;
  Chart1.Draw;
  Chart1.MarginUnits:=muPixels;
  Chart1.MarginRight:=100;
  Chart1.Legend.CustomPosition:=true;
  Chart1.Legend.Left:=Chart1.Width-Chart1.Legend.Width-10;
  Chart1.Legend.Top:=Chart1.Axes.Bottom.PosAxis-Chart1.Legend.Height-10;
TestAlways
Re: Legend Position
Post by TestAlways » Tue Nov 30, 2010 4:36 pm
This works until I resize the chart--the legend stays in the same location.
I tried some before/after draw events, and they did not work.
Any suggestions?
Ed Dressel
Re: Legend Position
Post by Sandra » Wed Dec 01, 2010 3:40 pm
Hello Ed,
I have done next example using OnAfterDraw event and works fine for me.
var i: Integer;
  for i:=0 to 4 do
  Chart1.Align:= alClient;
  Chart1.Draw;
Could you please, tell us if previous code works as you want? If code doesn't work fine for you please, explain us which is the exactly problem.
TestAlways
Re: Legend Position
Post by TestAlways » Wed Dec 01, 2010 4:16 pm
The attached demo (using 8.06) draws the legend in the wrong location the first time. After a redraw, it works fine.
Ed D
Legend Location 2.zip
(2.99 KiB) Downloaded 652 times
Re: Legend Position
Post by Sandra » Fri Dec 03, 2010 11:50 am
Hello TestAlways,
If you want that legend location would be correct the first time, you need added Chart1.Draw twice in from create as do in next lines of code:
constructor TForm2.Create(aOnwer: TComponent);
  inherited;
  Series1.FillSampleValues(20);
  Series2.FillSampleValues(20);
  Series2.Title := 'this is a long description';
 Chart1.Draw;
 Chart1.Draw;
//  Chart1.MarginRight:=100;
I also inform you, there is recent version of TeeChartVCL(8.07) you can download it here.
