How to get YValue according to horiz. position of cursor?
Hello all,
I give up, after way too long time searching for a solution on my quite simple task!
With this code
tmpX, tmpY: Double;
Chart1[0].GetCursorValues(tmpX, tmpY);
I get the actual values under the mouse cursor, even though no series values are present under the cursor.
But how do I get the YValue of a series point equal to the horizontal position of the cursor?
I would like to use the function
Chart1[0].YValue[Index]
but how do I get the index of the YValue present on the vertical line of the cursor??
All functions I have found that return the actual cursor position seem to return the position in screen pixels.
I need the position in YValues (count)!
It all takes place in the MouseMove event, and the YValue must be "refreshed" all the time, which means that I can't use any Series.OnClicked events.
Hope I explained well, and thanks in advance!
With this code
tmpX, tmpY: Double;
Re: How to get YValue according to horiz. position of cursor?
Hi ChartIt,
You can retrieve the Cursor's XValue and YValue directly:
You can also convert pixels to values and vice versa with Axes' CalcPosPoint and CalcPosValue functions.
Pixels to Values:
For example, in OnMouseMove event, you have X and Y mouse position in pixels given as parameters, so you can do as follows:
Values to Pixels:
At any time (once the chart has been drawn) you can obtain the pixel where a value will be drawn:
You can also obtain the pixel for a determinate series' value, knowing it's index in the series:
Chart1.Title.Text.Text:=FloatToStr((Chart1.Tools[0] as TCursorTool).XValue);
Pixels to Values:
procedure TForm1.Chart1MouseMove(Sender: TObject; Shift: TShiftState; X,
Y: Integer);
var XValue: double;
XValue:=Chart1.Axes.Bottom.CalcPosPoint(X);
Chart1.Title.Text.Text:=FloatToStr(XValue);
XPixel:=Chart1.Axes.Bottom.CalcPosValue(10);
XPixel:=Chart1[0].CalcXPos(10);
I think we misunderstand each other.
As seen on the enclosed screen shot (from a measurement program I'm about to "copy") I want to get the YValue that is on the same horizontal position as the cursor, but not necessarily on the same vertical position.
My question is now:
How can I obtain the Index of the YValue in the series?
Do you get it?
My question is now:
Do you get it?
- Measurement.JPG (52.09 KiB) Viewed 24590 times
Hi ChartIt,
Take a look at the example at All Features\Welcome !\Chart Styles\Standard\Line (Strip)\Interpolating Line Series in the New Features demo included with the installation.
Thanks for that, but I don't want/need to interpolate the value between the points, just get the value closest to the cursor.
I'm pretty sure it is just a very simple line of code that I need to retrieve that index as described above, but which code?
Hi ChartIt,
Then, it sounds like you are looking for something like TNearestTool. Take a look at the demo at All Features\Welcome !\Tools\Nearest PointChartIt wrote:Thanks for that, but I don't want/need to interpolate the value between the points, just get the value closest to the cursor.
I don't think that's the function I need, and it sounds like overkill to use a separate Tool in my case.
I'm actually still pretty sure that I'm just missing one line of code.
As discussed above:
My question is still:
Maybe something like:
YValueIndex := Chart1[0].CalcYValueIndex(CursorsXPositionInPixel);
Then I could use this YValueIndex to finally get my value:
Result := Chart1[0].YValue[YValueIndex];
As discussed above:
Hi ChartIt,
That's why we propose to do the same manually in the Interpolating Line Series example in the features demo mentioned above. Actually, we loop in the series until we find the two points where the mouse is between, and we calculate the Y value with trigonometry arithmetic.
There isn't a method like the one you suggest (CalcYValueIndex nor with another name) because it wouldn't be enough generic. For example, what Index should this function return for an Horizontal Line Series?ChartIt wrote:My question is still:
Result := Chart1[0].YValue[YValueIndex];![]()
function TLineInterpolateForm.InterpolateLineSeries(Series: TChartSeries;
XValue: Double): Double;
result:=InterpolateLineSeries(Series,Series.FirstDisplayedIndex,Series.LastValueIndex,XValue);
FirstIndex, LastIndex: Integer; XValue: Double): Double;
var
Index: Integer;
dx,dy: Double;
for Index:=FirstIndex to LastIndex do
if Series.XValues.Value[Index]>XValue then break;
//safeguard
if (Index<1) then Index:=1
else if (Index>=Series.Count) then Index:=Series.Count-1;
// y=(y2-y1)/(x2-x1)*(x-x1)+y1
dx:=Series.XValues.Value[Index] - Series.XValues.Value[Index-1];
dy:=Series.YValues.Value[Index] - Series.YValues.Value[Index-1];
if (dx<>0) then
result:=dy*(XValue - Series.XValues.Value[Index-1])/dx + Series.YValues.Value[Index-1]
else result:=0;
procedure TLineInterpolateForm.Chart1AfterDraw(Sender: TObject);
var xs, ys, i: Integer;
if CheckBox1.Checked then
xs := Chart1.Axes.Bottom.CalcXPosValue(xval);
for i:=0 to Chart1.SeriesCount - 1 do
ys := Chart1[i].GetVertAxis.CalcYPosValue(InterpolateLineSeries(Chart1[i],xval));
Chart1.Canvas.Brush.Color := Chart1[i].Color;
Chart1.Canvas.Ellipse(xs-4,ys-4,xs+4,ys+4);
procedure TLineInterpolateForm.ChartTool1Change(Sender: TCursorTool; x,
y: Integer; const XValue, YValue: Double; Series: TChartSeries;
ValueIndex: Integer);
var
i: Integer;
xval := XValue;
With Chart1.Title.Text do
Clear;
Add(Chart1[i].Name + ': Y('+FloatToStrF(XValue, ffNumber, 8, 2)+')= ' +
FloatToStrF(InterpolateLineSeries(Chart1[i],XValue), ffNumber, 8, 2)+#13#10);
I got it!!!
I just used the Cursor Tool that I'm using anyway!
with Chart1.Tools.Add(TCursorTool) as TCursorTool do
FollowMouse := True;
ScopeStyle := scsEmpty;
Pen.Visible := False;
Series := Chart1[0]; //A series must be assigned to show cross hair with cursor tool.
Style := cssVertical;
YValueIndex := (Chart1.Tools.Items[0] as TCursorTool).NearestPoint(cssVertical, Dummy);
Hi ChartIt,
I'm glad to hear it! ^^ChartIt wrote:I got it!!!
