Guilz
Post
by Guilz » Thu Nov 25, 2010 10:15 am
Hi Teechart support Team,
2 questions:
1 - How can I change Mark text without using _OnGetSeriesMark method (I would like to change mark text for 1 serie not for all my series) ?
With AxTChart.Series(AxTChart.SeriesCount - 1).Marks.Item(nbMarks)
End With
->but unfortunately the .Text property is readonly...
2 - My need is to display information on my chart (a symbol and a text -> gray circle and Island Reversal text in my example)) like in the chart bellow:
- marks.png (25.63 KiB) Viewed 16012 times
What is the best way to do this ?
Thanks for your help
Guilz
Post
by Yeray » Thu Nov 25, 2010 11:36 am
Hi Guliz,
Guilz wrote:1 - How can I change Mark text without using _OnGetSeriesMark method (I would like to change mark text for 1 serie not for all my series) ?
You can change the label for each point:
TChart1.Series(i).PointLabel(0) = "my text"
Guilz wrote:2 - My need is to display information on my chart (a symbol and a text -> gray circle and Island Reversal text in my example)) like in the chart bellow:
Here you have a simple example showing how to achieve a chart similar that the picture you've attached:
Private Sub Form_Load()
TChart1.Aspect.View3D = False
TChart1.AddSeries scFastLine
TChart1.Series(0).FillSampleValues 1000
TChart1.AddSeries scPoint
With TChart1.Series(1)
.Color = RGB(10, 10, 10)
With .Marks
.Visible = True
.Transparent = True
.Font.Color = vbGrayText
.Arrow.Visible = False
.ArrowLength = -15
End With
With .asPoint.Pointer
.Style = psCircle
.Pen.Visible = False
.HorizontalSize = 8
.VerticalSize = 8
.Transparency = 50
End With
End With
Dim i, c As Integer
For i = 0 To TChart1.Series(0).Count - 1
If i Mod 75 = 0 Then
c = Rnd * 255
TChart1.Series(1).AddXY TChart1.Series(0).XValues.Value(i), TChart1.Series(0).YValues.Value(i), "point nº" + Str$(TChart1.Series(1).Count), RGB(c, c, c)
End If
Next i
TChart1.Axis.Bottom.Labels.Style = talValue
Guilz
Post
by Guilz » Thu Nov 25, 2010 12:01 pm
It is working like a charm, as usual
Thanks a lot
Guilz
Post
by Yeray » Thu Nov 25, 2010 1:44 pm
Hi Guliz,
Pleased to be helpful!
Guilz
Post
by Guilz » Thu Nov 25, 2010 2:52 pm
I have an another issue with marks:
We use marks on chart and create function to let space between marks (for readability problem)
- marks00.png (61.5 KiB) Viewed 15978 times
But on Candle Chart we would like to have the same logic with only 1 mark (Open, Close, High, Low and corresponding date) and not one mark for Open one mark for close one mark for High like in the screen shot bellow...
How can we do that ?
Guilz
- Marks01.png (38.16 KiB) Viewed 15975 times
Post
by Sandra » Thu Nov 25, 2010 4:38 pm
Hello Guilz,
You can use in OnGetSeriesMark event a code as the next:
TeeCommander1.Chart = TChart1
TChart1.AddSeries scCandle
TChart1.Series(0).FillSampleValues (5)
TChart1.Series(0).Marks.Visible = True
Private Sub TChart1_OnGetSeriesMark(ByVal SeriesIndex As Long, ByVal ValueIndex As Long, MarkText As String)
MarkText = "Data:" & Str$(TChart1.Series(0).asCandle.DateValues.Value(ValueIndex)) & vbCr & "Open" & Str$(TChart1.Series(0).asCandle.OpenValues.Value(ValueIndex)) & vbCr & "Close" & Str$(TChart1.Series(0).asCandle.CloseValues.Value(ValueIndex)) & vbCr & "High" & Str$(TChart1.Series(0).asCandle.HighValues.Value(ValueIndex)) & vbCr & "Low" & Str$(TChart1.Series(0).asCandle.LowValues.Value(ValueIndex))
Could you tell us, if code works as you want?
Guilz
Post
by Guilz » Thu Nov 25, 2010 5:19 pm
Hi Sandra,
It is not working fine for me -
For Candle chart type, I would like to have less Marks for readability problem.
In fact .Marks.DrawEvery property does not work fine with candle type (see my picture to understand the problem)
Guilz
Post
by Sandra » Fri Nov 26, 2010 8:56 am
Hello Guilz,
I couldn't reproduce your problem using TeeChartAcitvex2010 and next code:
TChart1.Series(0).FillSampleValues (25)
TChart1.Series(0).Marks.DrawEvery = 2
Could you please, send us a simple project or modify previous code? So we can reproduce your problem here. Moreover, you can tell us which version of TeeChart ActiveX are you using now?
Petar
Post
by Petar » Wed Dec 15, 2010 2:46 pm
Thanks Sandra,
indeed it's working also well with Version 8.
Cheers
Petar
