Hello
Does anyone know, how I can modify the background of my TChart?
I want to color the range 0-10 (X-Value) in blue, the range 10-90 (X-Value) in dark blue and the range 90-100 (X-Value) in black.
I didn't really find information about this in the internet or the tutorials...
Thanks a lot !!
Modify Background
Re: Modify Background
Hello ICS,
I recommend two options for change color of your TChart background:
First: Using property Gradient of Chart Panel and Chart Walls as do in next lines of code:
Second: Using property Gradient of Chart Panel and change property visible of Walls to false, as do below:
tChart1.Panel.Gradient.StartColor = Color.White;
tChart1.Panel.Gradient.MiddleColor = Color.Blue;
tChart1.Panel.Gradient.EndColor = Color.Black;
tChart1.Walls.Back.Gradient.StartColor = Color.White;
tChart1.Walls.Back.Gradient.MiddleColor = Color.Blue;
tChart1.Walls.Back.Gradient.EndColor = Color.Black;
tChart1.Walls.Back.Visible = false;
Hi ICS,
You could use Color Band tools to do it. Take a look at the example at All Features\Welcome !\Tools\Color Band.
You'll find this and many other examples in the Feature demo included with the installation. A shortcut to it can be found in the StartMenu, in TeeChart programs group.
Hola
Gracias for the answer.
I added a color band. This is exactly what I needed
I couldn't use the "panel.gradient", because I need a defined line. In the Gradient, the color change is half transperant.
Hasta luego
Eric
Hasta luego
Eric
Hola Eric,
You're welcome.
Salut!
You're welcome.
Salut!
