Position of a SubChart
WilliEbert
Post by WilliEbert » Fri Oct 29, 2010 4:20 pm
we have to position a SubChart outside the Chart Axis, e.g. under the Chart.Legend. Because the SubChart should not hide any info of the Main chart, but if we try this to position the SubChart under the Legend there are many problems :
procedure TGraphForm.ChartIntResize(Sender: TObject);
ChartTool3.Charts[0].Chart.Left := ChartInt.Legend.Left -50 ;
ChartTool3.Charts[0].Chart.Top := ChartInt.Height - ChartTool3.Charts[0].Chart.Height -50 ;
This code does not function well, because there is now way to deal with Form maximize and if only the Chart is resizing the SubChart is only following very slow the Main Chart Position.
Can you help us?
Your sincerely
Willi Ebert
Re: Position of a SubChart
Post by Narcís » Mon Nov 01, 2010 5:53 pm
Hi Willi,
Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
WilliEbert
Post by WilliEbert » Tue Nov 02, 2010 3:21 pm
Hello Narcís,
here is a test project. The SubChart stays not under the legend like it is defined in the Chart1Resize procedure.
Your sincerely
Willi
SubChart.zip
(12.33 KiB) Downloaded 453 times
Post by Narcís » Tue Nov 02, 2010 3:52 pm
Hi Willi,
Implementing OnResize as shown below works fine for me here. Chart needs to be drawn so that legend properties have correct values.
procedure TForm2.Chart1Resize(Sender: TObject);
  Chart1.Draw;
  ChartTool1.Charts[0].Chart.Left := Chart1.Legend.Left -50 ;
  ChartTool1.Charts[0].Chart.Top := Chart1.Legend.ShapeBounds.Bottom;
WilliEbert
Post by WilliEbert » Tue Nov 02, 2010 5:12 pm
Hello Narcís,
thank you very much for your help. Chart1.Draw was the key.
Your sincerely
Willi Ebert
