Series Format->Marks->Format question.
TonyVSUK
Post by TonyVSUK » Thu Oct 14, 2010 1:20 pm
I have a line series.
If you edit the series in the editor, select the "Marks" tab, then select "Format" there are options for "Colour", "Transparency", "Pattern" and "Transparent".
How do I access these in code? I cannot find the settings. I know it must be part of the "Marks" class, I just cannot figure out which settings.
Thanks in advance,
Tony.
Re: Series Format->Marks->Format question.
Post by Sandra » Thu Oct 14, 2010 2:35 pm
Hello Tony,
If you want change Format of Marks to running time you need do next:
Transaprent property:
 TCahrt1.Series(0).Marks.Transparent = True
Percentage of transparency
TChart1.Series(0).Marks.Transparency = 50
Change Color of Marks:
 TChart1.Series(0).Color = vbBlack
Change pattern of marks using brush propriety: In this one you are need assign for each mark its brush style, because at the moment isn't possible assign for all marks their style at once. I have added it in wish-list with number (TA05015209) to be considered as an enhancement for future releases.
 Dim i As Integer
 For i = 0 To TChart1.Series(0).Count
  TCahrt1.Series(0).Marks.Item(i).Brush.Style = bsCross
 Next
TonyVSUK
Post by TonyVSUK » Thu Oct 14, 2010 3:16 pm
Sorry, hit submit instead of preview for this message.
TonyVSUK
Post by TonyVSUK » Thu Oct 14, 2010 3:21 pm
The transparent and transparency work ok. Thanks for those.
But I don't want to change the colour of the marks. The setting is the background colour of the surrounding box around the marks, its the background of the box that the mark is in (if that makes sense). I can change it using the editor, but I need to be able to do it in code.
If you look at the attached, the marks box has a colour white, pattern colour light blue and the pattern is "fill 80%".
Does that make sense?
Post by Sandra » Fri Oct 15, 2010 8:52 am
Hello Tony,
I fear its that this is a bug known of the brush object (TV52015167). I have increased its priority and we try to fix it for next maintenance releases.
