Delphi XE
NDzubiel
Delphi XE
Post by NDzubiel » Mon Oct 04, 2010 4:06 pm
I installed TeeChart Pro 2010 Full Source Code and recompiled everything for Delphi XE.
It seems, that the installation of the BPL / DCU files does not work,
because - not backup directory is created and the old files are still in place,
e.g. in C:\Program Files (x86)\Embarcadero\RAD Studio\8.0\lib\win32\release
so is there a fix or do I have to do the install manually ?
Thanks for infos.
Nils
Re: Delphi XE
Post by Narcís » Tue Oct 05, 2010 7:03 am
Hi Nils,
The easiest option is using TeeRecompile tool shipped with the source code installer. Do you get any specific error message so that we can advise on how to solve it?
NDzubiel
Re: Delphi XE
Post by NDzubiel » Tue Oct 05, 2010 7:05 am
Good morning,
I am using the tool - and it is not working - this is my problem ...
Nils
Re: Delphi XE
Post by Narcís » Tue Oct 05, 2010 7:19 am
Hi Nils,
Could you please post any error message you may get at the Log tab?
NDzubiel
Re: Delphi XE
Post by NDzubiel » Tue Oct 05, 2010 9:07 am
I could not Upload a log file - the board does not allow it -
and it's to long for this text field ...
I've attached a hardcopy from the Delphi XE directory ..
Nils
Delphi XE LIB Directory.jpg (286.1 KiB) Viewed 6970 times
Re: Delphi XE
Post by Narcís » Tue Oct 05, 2010 9:16 am
Hi Nils,
Could you please paste the last lines of the log files where any error may appear?
NDzubiel
Re: Delphi XE
Post by NDzubiel » Tue Oct 05, 2010 9:32 am
I've checked - there are no errors within the file.
I send you a copy to info@steema.com
Nils
Re: Delphi XE
Post by Narcís » Tue Oct 05, 2010 10:17 am
Hi Nils,
Do you have the "Install the packages into IDEs" checkbox enabled when running TeeRecompile?
NDzubiel
Re: Delphi XE
Post by NDzubiel » Tue Oct 05, 2010 11:00 am
Yes, I have.
I have Delphi 2007 / 2010 / XE installed. 2007 and 2010 are okay. Just XE is not working correctly.
Nils
Re: Delphi XE
Post by Narcís » Tue Oct 05, 2010 11:07 am
Hi Nils,
What about the binary installer for XE? Also, we are now testing the installers for the final 2010.01 release and the source code installer worked for XE here.
NDzubiel
Re: Delphi XE
Post by NDzubiel » Tue Oct 05, 2010 2:38 pm
I tried,
the system says installed - no error messages - but in the lib path - still the old
Delphi XE files - no backup directory.
Nils
Re: Delphi XE
Post by Narcís » Tue Oct 05, 2010 2:41 pm
Hi Nils,
We have just posted the new v2010 maintenance release. Can you please check if new installers solve the problem at your end? Do you have any other machine with the same IDE where you can make the same test? It maybe a fault with IDEs installation.
