Map 0 from Axes.Left to 0 from Axes.Right
Neelam
Post by Neelam » Mon Jul 12, 2010 7:28 pm
I have chart with dollar amount on left axes and non dollar value on right axis. If both sides have just positive values it working fine. In my case left axis has negative and positive values, but right axis has just positive. And 0 from right axis did not line up with 0 on left axis. How can I fix it? Line up 0 from both axis.
Re: Map 0 from Axes.Left to 0 from Axes.Right
Post by Sandra » Tue Jul 13, 2010 9:24 am
Hello Neelman,
You could do a similar code that next example that works fine here with last version of TeeChart .Net:
           private Steema.TeeChart.Styles.Line line1;
               Random  rnd = new Random();
               line1 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
               line1.FillSampleValues();
               line1.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Both;
Could you please say us if previous lines of code works as you want? If it in not a good solution for you, please you could modify the code because we can reproduce exactly, your problem here and we can try to make a solution for you.
Neelam
Post by Neelam » Wed Jul 14, 2010 3:26 pm
I have TeeChart version 3.5.3700.30575 and this example did not work. Problem still exists: 0 from left Axis did not line up with 0 from right axis in case if left value below 0.
Please advise.
Thnaks.
Post by Sandra » Thu Jul 15, 2010 10:48 am
Hello Neelam,
I have made other code using SetMinMax() property that allow align correctly Right and Left axes values. I think that use similar code as next for solves your problem.
  private Steema.TeeChart.Styles.Line line1, line2;
            double MinValue, MaxValue;
            line2 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            line1.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Left;
            line2.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Right;
            for (int i = 0; i < 10; i++)
                if (i < 5)
                    line1.Add(i * 2, -5 + i);
                else if (i == 5)
                    line1.Add(i * 2, 0);
                    line1.Add(i * 2, i - 5);
                line2.Add(i, i);
           MinValue= Math.Min(line1.MinYValue(), line2.MinYValue());
           MaxValue = Math.Max(line1.MaxYValue(), line2.MaxYValue());
            tChart1.Axes.Left.SetMinMax(MinValue, MaxValue);
            tChart1.Axes.Right.SetMinMax(MinValue,MaxValue);
Could you please, tell us if previous code works as you want?
Neelam
Post by Neelam » Thu Jul 22, 2010 5:44 pm
This example is different from my objective. Left and Right axes have different scales. I cannot set same scale for left and right axis. In my case left axis has one scale (dollar amount) and right axis has another scale (non dollar numbers). If left and right axes have positive values it’s aligning correctly, because its starts from 0(Min=0). But if left axis has negative value (Min<0 for example= -1980) and right axis has just positive number (Min=0) it aligns -1980 on left side to 0 on right side. I need to adjust right axis scale to line up 0 from left axis to 0 on right axis.
Post by Yeray » Fri Jul 23, 2010 4:01 pm
Hi Neelam,
We'll study it and we'll be back to you here asap.
Post by Sandra » Tue Jul 27, 2010 10:58 am
Hello Neelam,
I have made a simple example using property of axes, EndPosition, and I think that you can use it in your application for solve your problem with axes.
        private Steema.TeeChart.Styles.Line lineSeries1;
                if (i < 5)
                else if (i == 5)
                line2.Add(i, i);
            MinValue = Math.Min(line1.MinYValue(), line2.MinYValue());
            tChart1.Axes.Right.SetMinMax(line2.MinYValue(), line2.MaxYValue());
            tChart1.Draw();
            int zeroPos = tChart1.Axes.Left.CalcPosValue(0.0);
            int axisSize = tChart1.Axes.Left.IAxisSize;
            tChart1.Axes.Right.StartEndPositionUnits = Steema.TeeChart.PositionUnits.Pixels;
            tChart1.Axes.Right.EndPosition = zeroPos - 34;
Could you please say us if previous code works as you want?
Neelam
Post by Neelam » Fri Jul 30, 2010 6:32 pm
Can you explain from last line of code 'tChart1.Axes.Right.EndPosition = zeroPos - 34; ' what is 34? What is comes from?
Post by Sandra » Mon Aug 02, 2010 12:18 pm
Hello Neelman,
Value 34 is a value that I calculate, because axes right position, exactly matches with position 0 of left axis as there are a difference some pixels when you draw axis right that start to zeroPos. If you prefer you can calculate it value using next lines of code:
           int axisSize = (int)(tChart1.Axes.Right.IAxisSize / tChart1.Axes.Right.MaxYValue);
            tChart1.Axes.Right.EndPosition = zeroPos - (axisSize+8);
Can you please, say us if our solution works fine for you?
Neelam
Post by Neelam » Tue Aug 10, 2010 3:42 pm
Still not working as expected. In line "tChart1.Axes.Right.EndPosition = zeroPos - (axisSize+8);" what is meanning for 8?
Post by Sandra » Wed Aug 11, 2010 9:48 am
Hello Nelman,
We don't sure that you want do exactly. Could you please send us a simple code, so we can try to find a good solution for you?
Neelam
Post by Neelam » Tue Sep 07, 2010 3:53 pm
Sandra wrote:Hello Nelman,
Below is a simple code to reproduce this issue. Create project, add chart control and name it tcCurve.
Run project and on chart you will see issue.
Private Sub LoadChart()
        Dim arBarSeriesA As New Steema.TeeChart.Styles.Bar
        Dim arBarSeriesB As New Steema.TeeChart.Styles.Bar
        Dim arBarSeriesA1 As New Steema.TeeChart.Styles.Bar
        Dim arBarSeriesB1 As New Steema.TeeChart.Styles.Bar
        tcCurve.Axes.Left.Grid.Visible = True
        tcCurve.Axes.Left.Grid.Style = Drawing2D.DashStyle.Solid
        arBarSeriesA.Labels.Add(Format(3000, "$##,##0.00"))
        arBarSeriesA.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Right
        arBarSeriesA.Add(3000)
        arBarSeriesA.ShowInLegend = True
        arBarSeriesA.BarWidthPercent = 120
        arBarSeriesA.Marks.Angle = 90
        arBarSeriesA.OffsetPercent = -30
        tcCurve.Series.Add(arBarSeriesA)
        arBarSeriesA1.Labels.Add(Format(2560, "$##,##0.00"))
        arBarSeriesA1.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Right
        arBarSeriesA1.Add(2560)
        arBarSeriesA1.ShowInLegend = True
        arBarSeriesA1.BarWidthPercent = 120
        arBarSeriesA1.Marks.Angle = 90
        arBarSeriesA1.OffsetPercent = -30
        tcCurve.Series.Add(arBarSeriesA1)
        arBarSeriesB.Labels.Add(-1000)
        arBarSeriesB.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Left
        arBarSeriesB.Add(-1000)
        arBarSeriesB.ShowInLegend = True
        arBarSeriesB.BarWidthPercent = 120
        arBarSeriesB.Marks.Angle = 90
        arBarSeriesB.OffsetPercent = -30
        tcCurve.Series.Add(arBarSeriesB)
        arBarSeriesB1.Labels.Add(1500)
        arBarSeriesB1.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Left
        arBarSeriesB1.Add(1500)
        arBarSeriesB1.ShowInLegend = True
        arBarSeriesB1.BarWidthPercent = 120
        arBarSeriesB1.Marks.Angle = 90
        arBarSeriesB1.OffsetPercent = -30
        tcCurve.Series.Add(arBarSeriesB1)
        tcCurve.Refresh()
Post by Narcís » Wed Sep 08, 2010 2:21 pm
Hi Neelam,
Can you please try running the example Sandra posted? I think it already does what you are asking for. You can convert them from C# to VB using any of those free on-line conversors:
http://www.carlosag.net/Tools/CodeTranslator/
http://authors.aspalliance.com/aldotnet ... slate.aspx
http://www.developerfusion.com/tools/co ... arp-to-vb/
http://converter.telerik.com/
If Sandra example don't fit your needs please net us know which is the exact problem you have with it.
Neelam
Post by Neelam » Mon Sep 13, 2010 5:59 pm
Did you try Sandra's example on my issue? It simple does not work for my case. I do not care about language (VB.net or C#).
Did you run my code? Did you see issue?
Post by Sandra » Tue Sep 14, 2010 10:39 am
Hello Neelam
I have modified your code, adding part of my code where I calculate value and position of axes (Right, Left). Please, check if next code works for you.
            LoadChart();
        private void LoadChart()
            Steema.TeeChart.Styles.Bar arBarSeriesA = new Steema.TeeChart.Styles.Bar();
            Steema.TeeChart.Styles.Bar arBarSeriesB = new Steema.TeeChart.Styles.Bar();
            Steema.TeeChart.Styles.Bar arBarSeriesA1 = new Steema.TeeChart.Styles.Bar();
            Steema.TeeChart.Styles.Bar arBarSeriesB1 = new Steema.TeeChart.Styles.Bar();
            tChart1.Axes.Left.Grid.Visible = true;
            tChart1.Axes.Left.Grid.Style = System.Drawing.Drawing2D.DashStyle.Solid;
            arBarSeriesA.Labels.Add("$##,##0.00");
            arBarSeriesA.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Right;
            arBarSeriesA.Add(3000);
            arBarSeriesA.ShowInLegend = true;
            arBarSeriesA.BarWidthPercent = 120;
            arBarSeriesA.Marks.Angle = 90;
            arBarSeriesA.OffsetPercent = -30;
            tChart1.Series.Add(arBarSeriesA);
            arBarSeriesA1.Labels.Add("$##,##0.00");
            arBarSeriesA1.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Right;
            arBarSeriesA1.Add(2560);
            arBarSeriesA1.ShowInLegend = true;
            arBarSeriesA1.BarWidthPercent = 120;
            arBarSeriesA1.Marks.Angle = 90;
            arBarSeriesA1.OffsetPercent = -30;
            tChart1.Series.Add(arBarSeriesA1);
            arBarSeriesB.Labels.Add(-1000);
            arBarSeriesB.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Left;
            arBarSeriesB.Add(-1000);
            arBarSeriesB.ShowInLegend = true;
            arBarSeriesB.BarWidthPercent = 120;
            arBarSeriesB.Marks.Angle = 90;
            arBarSeriesB.OffsetPercent = -30;
            tChart1.Series.Add(arBarSeriesB);
            arBarSeriesB1.Labels.Add(1500);
            arBarSeriesB1.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Left;
            arBarSeriesB1.Add(1500);
            arBarSeriesB1.ShowInLegend = true;
            arBarSeriesB1.BarWidthPercent = 120;
            arBarSeriesB1.Marks.Angle = 90;
            arBarSeriesB1.OffsetPercent = -30;
            tChart1.Series.Add(arBarSeriesB1);
            MinValue = Math.Min(Math.Min(arBarSeriesA.MinYValue(), arBarSeriesA1.MinYValue()), Math.Min(arBarSeriesB.MinYValue(), arBarSeriesB1.MinYValue()));
            MaxValue = Math.Max(Math.Max(arBarSeriesB.MaxYValue(), arBarSeriesB1.MaxYValue()), Math.Max(arBarSeriesA.MaxYValue(), arBarSeriesA1.MaxYValue()));
            tChart1.Axes.Right.SetMinMax(Math.Min(arBarSeriesA.MinYValue(), arBarSeriesA1.MinYValue()), Math.Max(arBarSeriesA.MaxYValue(), arBarSeriesA1.MaxYValue()));
            tChart1.Draw();
            tChart1.Axes.Right.EndPosition = zeroPos - 38;
If previous code doesn’t work for you, could you please, modify or explain what is your exactly problem? Because we can try help you.
