More custom axes with same min/max are not drawn equally!
ChartIt
Post by ChartIt » Mon Aug 23, 2010 5:45 pm
I just upgraded from V7 to V2010, and now I'm angry.
To list all the errors I've found would take too long time,
and lead the focus away from the most critical things at the moment.
They are:
1:
Crash when selecting font tab in the chart editor.
The different fonts can be changed with the Delphi Object Inspector without problems.
See attached screen shot.
2:
When showing more custom axes with the same range (min/max), the first one appears to be "shorter" than the rest.
This results e.g. in grid lines not being positioned perfectly on top of each other.
I'm using Delphi 2006 and TChart v2010
Thanks in advance for any help!
NOT OK
More series with overlay.JPG (45.68 KiB) Viewed 13807 times
OK
One series OK.JPG (38.58 KiB) Viewed 13802 times
CRASH
Crash when choosing font tab.JPG (128.67 KiB) Viewed 13796 times
Re: More custom axes with same min/max are not drawn equally!
Post by Yeray » Tue Aug 24, 2010 2:55 pm
Hi ChartIt,
ChartIt wrote:1:
This is a known problem we've already fixed for the next maintenance release (TV52014813)
ChartIt wrote:2:
I'm trying to reproduce it with the following code but the grid lines are well aligned.
uses series;
var i, j: Integer;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  for i:=0 to 3 do
    Chart1.AddSeries(TFastLineSeries);
    Chart1[i].Add(Random(10) + 100);
    for j:=1 to 25 do
      Chart1[i].Add(Chart1[i].YValue[j-1] + Random(5) - 2.4);
    if (i = 0) then
      Chart1[i].VertAxis:=aRightAxis;
      Chart1.Axes.Right.SetMinMax(75,125);
      Chart1.Axes.Right.LabelsFont.Color:=Chart1[i].Color;
    end
      Chart1.CustomAxes.Add;
      Chart1[i].CustomVertAxis:=Chart1.CustomAxes[i-1];
      Chart1[i].CustomVertAxis.OtherSide:=true;
      Chart1[i].CustomVertAxis.PositionUnits:=muPixels;
      Chart1[i].CustomVertAxis.PositionPercent:=-i*45;
      Chart1[i].CustomVertAxis.Axis.Visible:=false;
      Chart1[i].CustomVertAxis.SetMinMax(75,125);
      Chart1[i].CustomVertAxis.LabelsFont.Color:=Chart1[i].Color;
  Chart1.MarginRight:=20;
So maybe you are setting a different SetMinMax to one axis and the others?
Please, try to change the code above so the problem can be reproduced here, or arrange a simple example project for the same purpose.
ChartIt
Post by ChartIt » Wed Aug 25, 2010 5:07 am
Thanks for your reply.
With this code you should be able to see the issue:
var i, j: Integer;
for i:=0 to 3 do
Chart1.Add(Random(10) + 100);
for j:=1 to 25 do
Chart1.Add(Chart1.YValue[j-1] + Random(5) - 2.4);
if (i = 0) then
Chart1.CustomVertAxis:=Chart1.CustomAxes;
Chart1.CustomVertAxis.OtherSide:=true;
Chart1.CustomVertAxis.PositionUnits:=muPixels;
Chart1.CustomVertAxis.PositionPercent:=-i*45;
Chart1.CustomVertAxis.Axis.Visible:=false;
Chart1.CustomVertAxis.SetMinMax(0,4);
Chart1[i].CustomVertAxis.Increment := (Chart1[i].CustomVertAxis.Maximum - Chart1[i].CustomVertAxis.Minimum)/10;
end
Chart1[i].CustomVertAxis:=Chart1.CustomAxes[i];
Chart1[i].CustomVertAxis.SetMinMax(0,400);
When making the Chart big you should see a double grid line, this time in the middle (at 2/200).
Could it be a rounding issue when I'm calculating the Increment?
In the meanwhile I've found another critical issue:
I can't change the cursor by code, it only works with the Chart Editor.
A new project with a fresh TChart, and the following code:
Chart1.Cursor := crHourGlass;
doesn't change anything.
Do I have to call any function after changing the cursor to get it updated?
With v7 I didn't experience this.
Best Regards
Post by Yeray » Wed Aug 25, 2010 3:33 pm
Hi ChartIt,
I can't see the double grid line you mention, even with the chart maximized or zooming.
Anyway, you can hide all the grid lines except of one of them. Here it is the example:
uses Series;
var i, j: Integer;
  Chart1.Align:=alClient;
  for i:=0 to 3 do
    for j:=1 to 25 do
    with Chart1[i].CustomVertAxis do
      OtherSide:=true;
      if (i = 0) then
        SetMinMax(0,4)
        SetMinMax(0,400);
        Grid.Visible:=false;
      Increment := (Maximum - Minimum)/10;
var i: Integer;
  for i:=0 to Chart1.CustomAxes.Count-1 do
    with Chart1.CustomAxes[i] do
      SetMinMax(CalcPosPoint(Chart1.Zoom.Y1), CalcPosPoint(Chart1.Zoom.Y0));
var i: Integer;
    if i = 0 then
      Chart1.CustomAxes[i].SetMinMax(0,4)
      Chart1.CustomAxes[i].SetMinMax(0,400);
ChartIt wrote:In the meanwhile I've found another critical issue:
Please, take a look at this thread, there are some solutions proposed:
http://www.teechart.net/support/viewtop ... sor#p29360
ChartIt
Post by ChartIt » Wed Aug 25, 2010 4:13 pm
See enclosed screen shot with my example.
Hiding the grid lines only solves the problem visual, but not the fact that the axes might be scaled different.
2:
Why is the function Chart.Cursor available if it's not working??
3:
New issue (or old??):
Sometimes heavy flickering of the chart when scrolling and changing values of points!
(Think this is solved in next release)
4:
Chart sometimes not repainting when other windows have been on top of it!
I'm getting more and more frustrated :(
Grid lines overlap.JPG (93.56 KiB) Viewed 13748 times
Post by Yeray » Fri Aug 27, 2010 3:11 pm
Hi ChartIt,
ChartIt wrote:1:
Here it is the project in Delphi 2006 + TeeChart v2010 that works fine for me here.
synchron_axes.zip
(412.91 KiB) Downloaded 601 times
Anyway, as you said, a pixel difference could be because of a rounding that has to be done when passing from values (doubles) to pixels (integers). I think there isn't too much we can do here apart from hiding grids.
ChartIt wrote: 2:
Yes, this is a known issue already in the wish list to be revised in future releases.
ChartIt wrote:3:
Depending on the number of points you have in your chart, the drawing process will be faster or slower. I'd recommend you to try to implement as many tips as possible from the Real-time Charting article.
If you still have troubles with it, don't hesitate to let us know.
ChartIt wrote:4:
Yes, this has been solved for the next maintenance release.
ChartIt
Post by ChartIt » Sun Aug 29, 2010 1:39 am
With Min/Max of 0/4 and 0/400 and then divided by 10 shouldn't lead to any rounding errors,
but never mind, I'll live with it.
3:
I have only the amount of values in the chart corresponding to the chart width in pixels (approx. 700), and have already implemented all relevant parts from that article.
Furthermore the problem didn't show up with TeeChart v7.
Any news about that maintenance release?
Post by Yeray » Mon Aug 30, 2010 3:27 pm
Hi ChartIt,
We are working on the next maintenance so it can be published asap.
The flickering problem you are suffering may also be fixed with the same bugfix that solved the repainting problem mentioned just above. If you want, you could send us a simple example project we can run as-is to reproduce the problem here and we'll confirm you if it has been solved in the actual sources or not.
ChartIt
Post by ChartIt » Mon Sep 06, 2010 5:14 am
I've found out that the flickering occurs after saving the chart as bitmap (SaveToBitmapFile).
See enclosed test program:
1:
Press btnStart - no flickering occurs.
2:
Press btnStop.
3:
Press btnSaveBmp.
4:
Press btnStart - flickering occurs.
Project1.zip
(426.68 KiB) Downloaded 641 times
Post by Yeray » Tue Sep 07, 2010 3:29 pm
Hi ChartIt,
Yes, I can confirm that it should be solved with the next maintenance release. I could reproduce the flickering with the first v2010 and not with the actual sources.
ChartIt
Post by ChartIt » Wed Sep 08, 2010 12:37 am
OK, thanks.
Do you have a work around for my current version??
Post by Narcís » Wed Sep 08, 2010 11:59 am
Hi ChartIt,
I can't think of a workaround for now but a "non-stable" pre-release version will be published imminently.
