Border of stacked bars
Timo
Post by Timo » Mon Aug 23, 2010 4:11 pm
I found a small bug. The border of a stacked bar is displayed in the color of the series if the value is 0. That is a bit confusing.
I'm using 8.06.
Cheers,
Timo
Projekte.rar
(2.29 KiB) Downloaded 550 times
Re: Border of stacked bars
Post by Yeray » Tue Aug 24, 2010 10:08 am
Hi Timo,
I could reproduce the problem so I've added it to the defect list to be fixed in future releases (TV52015106).
Note that it only happens in 2D.
And also note that as a workaround you could loop into your series and set as nulls those zero points:
uses series;
var bar1, bar2: TBarSeries;
    i, j: Integer;
  Chart1.View3D:=CheckBox1.Checked;
  bar1:=Chart1.AddSeries(TBarSeries) as TBarSeries;
  bar1.Add(0);
  bar1.Add(10);
  bar1.Pen.Width:=20;
//workaround
{  for i:=0 to Chart1.SeriesCount-1 do
    for j:=0 to Chart1[i].Count-1 do
      if Chart1[i].YValues[j] = 0 then
        Chart1[i].SetNull(j);  }
procedure TForm1.CheckBox1Click(Sender: TObject);
Timo
Post by Timo » Tue Aug 24, 2010 10:14 am
Thanks!
