Memory Leak GDI+
Memory Leak GDI+
I'd removed the line IXORCanvas:=TTeeCanvas3D.Create from InitWindow and put in the Constructor Create and trouble keep on.
What should I do now? Any solve else?
I'd sent a print screen from MM4.
thanks
thanks
- print screen of the Application and MM4
- email-memory-leak-tchart.jpg (164.99 KiB) Viewed 7700 times
Re: Memory Leak GDI+
I´m using the >>>TeeChart Pro 2010 Full Source Code >>>Version 0.4455.0.0 and like you can see the Memory Leak keep on. Have you see the atachment file (print mm4) wich I sent you?
Hi Fausto,
You may be doing something different than me. Here is what I'm doing:
Could you please modify the example above so we can reproduce the error here?
uses Series, TeeGDIPlus;
var FGDIPlus: TTeeGDIPlus;
with Chart1.AddSeries(TBarSeries) as TBarSeries do FillSampleValues();
FGDIPlus := TTeeGDIPlus.Create(Self);
FGDIPlus.TeePanel := Chart1;
ReportMemoryLeaksOnShutdown := True;
If you change the transparency of the WALLS you can memory on. In your example you forgot put the GDIPlus (Active = True).
I'd attached other example. I my example you should use the ROTATE TOOL and you can see the memory usage UP and UP UP UP UP.
delphi7
delphi7
- MEMORY leak_FAUSTO.rar
- example in delphi7 with WALLS (transparency 70%) and memory leak on
- (29.67 KiB) Downloaded 234 times
In transparency in SERIES I´d found problems too
Hi Fausto,
I could reproduce the problem with the latest published version but with the actual sources it seems to work fine.
So it's with most probability related with the problem discussed here and here (TV52014993). It has been already fixed for the next maintenance release.Fausto Jr. wrote:I my example you should use the ROTATE TOOL and you can see the memory usage UP and UP UP UP UP.
Could you please explain us how can we reproduce it?Fausto Jr. wrote:In transparency in SERIES I´d found problems too
When the next release will be available? I nedd this urgently.
Here the problem has been reproduced with the code:
uses
Series, TeeGDIPlus;
var
TBarSeries(Chart1.Series[0]).Transparency := 50; // THIS LINE INVOKE MEMORY LEAK (USE ROTATE TOOL TO SEE MEMORY USAGE UP UP...)
FGDIPlus.Active:=true;
uses
Series, TeeGDIPlus;
var
- properties of the release
- FileTeeChart2010SourceCode PROPERTIES.JPG (27.22 KiB) Viewed 7590 times
Hi Fausto,
As you are source code customer, I've sent the actual sources to the mail you have registered in this forums.
Could you please check if they correct the problem?
Could you re-send me the email? I changed my email because the older was written wrong.
Apologies!!!
Apologies!!!
Hi Fausto,
Just done!
Just done!
Yeray,
Thanks a lot buddy. Now, it's stable. And my boss is very happy.
Thankful,
Fausto Jr.
Thankful,
Fausto Jr.
Hi Fausto,
I'm glad to hear it!
Boas tardes!
Boas tardes!
