Export TeeChart to xaml Bug.
neurosoft
Post by neurosoft » Tue Jul 20, 2010 9:53 am
Hello.
I have problems with exporting of WPF TChart to Xaml.
So, I have created TeeChart instance by the following code:
TChart tChart = new TChart();
tChart.Series.Add(new Bar());
Bar series = tChart[0] as Bar;
series.Brush.ForegroundColor = Colors.Black;
GeometryDrawing drawing = new GeometryDrawing(Brushes.Black, new Pen(Brushes.Black, 1), new LineGeometry(new Point (0, 10), new Point(10, 0)));
series.Brush.Drawing = drawing;
tChart.Aspect.View3D = false;
for (int i = 0; i < 10; i++)
    series.Add(i);
series.ShowInLegend = false;
The result is represented by the picture:
And when I try to export this TeeChart to xaml, I recieve incorrect result (exported xaml in attachment
ExportedTeeChart.xaml.ZIP
(2.26 KiB) Downloaded 532 times
As you see, dashed lines are very thick and exported chart has no DrawingGeometry texture in Bar.
Re: Export TeeChart to xaml Bug.
Post by Sandra » Thu Jul 22, 2010 1:21 pm
retard Hello neurosoft,
Sorry for the delay, I can reproduce your problem and I communicate you that I have added bug in wish-list with number [TF02015043]. We will try to fix it for next maintenances releases of TeeChart.Net.
neurosoft
Post by neurosoft » Thu Jul 22, 2010 1:40 pm
Sandra, thanks for reply. I'll wait for next release with the hope, that the bug is fixed.
Post by Sandra » Mon Aug 02, 2010 8:43 am
Hello neurosoft,
I inform that bug with number (TF02015043) is not a bug, because HatchBrush does not exist in WPF/XAML. Moreover, I have added it in wish-list as a future request with number[TW16015062]to be implemented in future releases of TeeChartWPF.
neurosoft
Post by neurosoft » Wed Aug 11, 2010 6:35 am
Hello Sandra!
1) Besides export of DrawingGeometry, I wrote about very thick dashed grid lines in exported xaml picture (vertical and horizontal lines). Please, pay attention to this remark.
2) I did't create HatchBrush for the Bar, because HatchBrush is not System.Windows.Media.Brush. In Windows Forms TChart I used property Style of the Steema.TeeChart.Drawing.Brush to set HatchStyle of the Bar. But in WPF version type Steema.TeeChart.WPF.Drawing.Brush has no Style property. For creating texture of the Bar I use property Drawing. And it works. But, as you see, I have problems with export TChart to xaml. So, if you consider, that is not a bug (that is wrong for my opinion), tell me how I can create Hatch in the Bar with the correct exporting.
Post by Sandra » Thu Aug 12, 2010 9:11 am
Hello neurosoft,
OK. Could you please, send us a simple project in WPF, because we can reproduce your exactly problem here?
We don't consider it as a bug because TeeChart.WPF doesn't have HatchStyle property, so it's more a lack than a problem. We call this type of problems as "Feature Request" but, actually, wish or bug/defect lists are internally the same list. What changes is the category of the issue but most important for us is the priority we give to each issue and this is quite an important one.
neurosoft
Post by neurosoft » Thu Aug 12, 2010 12:24 pm
Hello!
Ok. I have created a simple WPF Application (
TChartExportTest.ZIP
(42.29 KiB) Downloaded 515 times
Please, add TeeChart.WPF.dll to the project references and run application. Then click "Export..." and choose the file for saving TeeChart. You will see that the exported TeeChart does not correspond to the original:
1) Dashed grid lines is very thick;
2) Background of the Bars became solid color, but in source TeeChart it was diagonal lines texture.
Is it normal behavior for the export? By the way, export to bitmap image works normally.
And I have not received the answer for the question about very thick dashed grid lines.
Post by Sandra » Fri Aug 13, 2010 11:38 am
Hello neurosoft,
We haven forgotten you, we'll inform you asap.
Post by Yeray » Mon Aug 23, 2010 3:20 pm
Hello neurosoft,
Excuse us for the delay. I could reproduce also in WinForms so we will study the problem and try to found what's wrong or missing here.
neurosoft
Post by neurosoft » Tue Aug 24, 2010 5:24 am
Thanks, Yeray!
We'll hope, that you will solve this issue.
Post by Yeray » Mon Aug 30, 2010 9:26 am
Hi neurosoft,
As we thought initially, implementing the HatchBrush property in WPF, would allow this in WPF and in extension in XAML exports (or vice versa).
neurosoft
Post by neurosoft » Tue Aug 31, 2010 11:31 am
Hi Yeray!
I have created TChart, represented by the picture
with help of following code:
    series.Add(i);
Exporting to xaml of the Drawing property has no require the HatchBrush property. It is easy to present the GeometryDrawing from the code, described above, in xaml:
    <GeometryDrawing Geometry="M 0,10 L 10,0 Z">
        <GeometryDrawing.Pen>
            <Pen Brush="Black" Thickness="1"/>
        </GeometryDrawing.Pen>
    </GeometryDrawing>
In other words, Steema.TeeChart.WPF.Drawing.ChartBrush has the Drawing property. Why this property is ignored by the exporting to xaml?
Now the Bar in the xaml (
(2.26 KiB) Downloaded 560 times
) of the exported TChart is represented by the following code:
<Rectangle Fill="#FF4466A3" Stroke="#FF293D62"
 Canvas.Left="..." Canvas.Top="..." Width="..." Height="..."/>
I think that it have to be represented by the another xaml:
 Canvas.Left="..." Canvas.Top="..." Width="..." Height="...">
    <Rectangle.Fill>
        <DrawingBrush TileMode="Tile" Viewport="0,0,10,10" ViewportUnits="Absolute">
           <DrawingBrush.Drawing>
               </GeometryDrawing>
           </DrawingBrush.Drawing>
        </DrawingBrush>
    </Rectangle.Fill>
</Rectangle>
So, the main question is how can I receive the correct xaml of a TChart with Drawing in the series Brush?
Post by Yeray » Thu Sep 02, 2010 9:57 am
Hi neurosoft,
We've implemented the HatchBrush property in WPF so the following will be possible with the next maintenance release:
            Steema.TeeChart.WPF.Styles.Bar series = new Steema.TeeChart.WPF.Styles.Bar(tChart1.Chart);
            series.FillSampleValues(6);
            series.Brush.Style = Steema.TeeChart.WPF.Drawing.HatchStyle.DarkUpwardDiagonal;
However, this still will not export to XAML. We are looking into getting this to export successfully to XAML.
