Left Align Legend Text?
erzsebet
Post by erzsebet » Thu Jul 29, 2010 5:45 pm
Is there a way that I can get the legend text to appear right next to the legend symbol? It appears that the legend items are alloted a width based upon the length of the longest text of all the legend items. This makes the legend items with shorter text display with a lot of space between the symbol and the text. Is there any way I can specify that the text for each item will be left aligned within the space alloted to it?
Thank you,
erzsebet
erzsebet
Re: Left Align Legend Text?
Post by erzsebet » Fri Jul 30, 2010 3:30 pm
How could I post a screenshot of this issue?
Thank you,
erzsebet
Post by Narcís » Fri Jul 30, 2010 3:35 pm
Hi erzsebet,
Upload it as an attachment at your replies here in the forums and use the "place inlane" feature to display it embedded in your text.
erzsebet
Post by erzsebet » Fri Jul 30, 2010 3:48 pm
Narcís, hello -
Thanks for answering my question about the attachment! I don't know how I missed the "Upload Attachment" tab! I will blame the fact that it is Friday!
In any event, this image shows the issue I am having with the legend:
Shows space between text and symbol.
I would like the "BORCHERS-BORCHERS, S." text to appear right next to the blue square, not far away like it is. I understand that the spacing is determined by the fact that "MANCHO PRADO-MANCHO PRADO" is longer than the "BORCHERS-BORCHERS, S" text, but is there some way to get manipulate the legend into displaying the text left aligned within the space allotted to each item?
Hope you have a great weekend!
-erzsebet
Post by Yeray » Fri Jul 30, 2010 4:51 pm
Hi erzsebet ,
What TeeChart version are you using?
I'm trying the following code with the latest sources and I can't reproduce the issue:
uses series;
  Chart1.Legend.Alignment:=laBottom;
  with Chart1.AddSeries(TPointSeries) do
    FillSampleValues();
    Title:='short string';
    FillSampleValues();
    Title:='very very very long string';
Could you please try the code above and see if you can see the same than me or not?
If you can't reproduce the problem with it, could you please try to modify it so we can reproduce the problem here?
erzsebet
Post by erzsebet » Thu Aug 05, 2010 9:54 pm
Yeray and Narcís, hello!
I hope you are both having a good day! Thanks so much for the time you've already put in to help me on this issue. Here is some more information.
I am using TeeChart Pro 8.06 with Delphi 2010. My issue with legend text alignment seems to be caused by overriding events to custom draw a customized legend. I have recreated the problem in the attached code. Please let me know if you have any suggestions on how I can get the legend text to appear closer to its associated symbol.
-erzsebet
erzsebet
Post by erzsebet » Thu Aug 05, 2010 10:00 pm
And now for the actual code! :wink:
-erzsebet
{ Note: My chart has one series, but users have the option to set the color for a range of values.         }
{ The legend is customized to display the range of each selection and not the series name or series value.  }
unit LegendTextAlignment_48352;
interface
uses
  Dialogs, Series, TeEngine, ExtCtrls, TeeProcs, Chart;
type
  { TScatterPlotObjectColor }
  TScatterPlotObjectColor = class
  private
    FColor: LongInt;
  public
    property Color: LongInt read FColor write FColor;
    constructor Create(const AColor : LongInt);
  TForm2 = class(TForm)
    Chart1: TChart;
    procedure FormClose(Sender: TObject; var Action: TCloseAction);
  private
    { Private declarations }
    FLegendList : TStringList;
    FLegendStartIndex, FCurrentLegendTextIndex, FCurrentLegendImageIndex : Integer;
    FDebugStr : String;
  public
    { Public declarations }
    procedure BeforeDrawChart(Sender: TObject);
    procedure AfterDraw(Sender: TObject);
    procedure LegendDraw(Sender: TObject; Series: TChartSeries; ValueIndex: Integer; R: TRect);
    procedure SetLegendText(Sender: TCustomAxisPanel; LegendStyle: TLegendStyle; Index: Integer; var LegendText: String);
const
  OWNS_OBJECTS_FLAG : Boolean = True;
var
  Form2: TForm2;
implementation
{$R *.dfm}
{ *******************TScatterPlotObjectColor Class*********************** }
constructor TScatterPlotObjectColor.Create(const AColor : LongInt);
  FColor := AColor;
{ **************************TForm2 Class********************************** }
  { Override events to customize legend. }
  Chart1.Legend.LegendStyle := lsValues;
  Chart1.OnBeforeDrawChart := BeforeDrawChart;
  Chart1.OnGetLegendText := SetLegendText;
  Chart1.Legend.Symbol.OnDraw := LegendDraw;
  Chart1.OnAfterDraw := AfterDraw;
  { Set up items needed for customization. }
  FLegendList := TStringList.Create(OWNS_OBJECTS_FLAG);
  FLegendList.AddObject('SHORT_RANGE', TScatterPlotObjectColor.Create(clRed));
  FLegendList.AddObject('VERYVERY_LONGRANGE', TScatterPlotObjectColor.Create(clGreen));
  FLegendStartIndex := 0;
  FCurrentLegendTextIndex := 0;
  FCurrentLegendImageIndex := 0;
  { Add the series. }
    FillSampleValues();
    Title:='title';    // This does not matter in our code, as the title is only displayed in the mouseover, and not in the legend.
procedure TForm2.FormClose(Sender: TObject; var Action: TCloseAction);
  if Assigned(FLegendList) then FreeAndNil(FLegendList);
  Chart1.OnBeforeDrawChart := nil;
  Chart1.OnGetLegendText := nil;
  Chart1.OnAfterDraw := nil;
  Chart1.Legend.Symbol.OnDraw := nil;
  Chart1.Legend.FirstValue := 0;
{ BeforeDrawChart overrides the TCustomChart OnDrawChart event to set the number of points to display in the legend - we *do not* want a legend item for every point! }
procedure TForm2.BeforeDrawChart(Sender: TObject);
  try
    if Assigned(FLegendList) then begin
      TChart(Sender).Legend.FirstValue := TChart(Sender).Series[0].YValues.Count - FLegendList.Count;
      TChart(Sender).Legend.Symbol.Position := spLeft;
      TChart(Sender).Legend.Symbol.Width := 5;
      FLegendStartIndex := TChart(Sender).Legend.FirstValue;
  except
    on E : Exception do begin
      FDebugStr := 'TForm2.BeforeDrawChart: Exception caught - ' + E.Message;
      //DebugValue(DebugStr);
{ SetLegendText overrides the OnGetLegendText event to allow customization of legend item text. }
procedure TForm2.SetLegendText(Sender: TCustomAxisPanel; LegendStyle: TLegendStyle; Index: Integer; var LegendText: String);{ HPDO-272 }
  try
    LegendText := FLegendList[FCurrentLegendTextIndex];
    Inc(FCurrentLegendTextIndex);
  except
      FDebugStr :=  'TScatterPlotDef.SetLegendText: Exception caught - ' + E.Message;
{ LegendDraw overrides the OnDraw event to allow customization of the legend symbol. }
procedure TForm2.LegendDraw(Sender: TObject; Series: TChartSeries; ValueIndex: Integer; R: TRect);
var
  ColorToPaint: LongInt;
  try
    with TLegendSymbol(Sender) do begin
      ColorToPaint := TScatterPlotObjectColor(FLegendList.Objects[FCurrentLegendImageIndex]).Color;
      Chart1.Canvas.Brush.Color := ColorToPaint;
      Chart1.Canvas.Pen.Color := clBlack;
      Chart1.Canvas.Rectangle(R);
    Inc(FCurrentLegendImageIndex);
  except
      FDebugStr :=  'TScatterPlotDef.LegendDraw: Exception caught - ' + E.Message;
{ AfterDraw overrides the TCustomChart OnAfterDraw event to reset all of the events and legend settings to their defaults prior to drawing other charts. }
procedure TForm2.AfterDraw(Sender: TObject);
  Chart1.Legend.LegendStyle := lsAuto;
end.
Post by Yeray » Fri Aug 06, 2010 2:18 pm
Hi erzsebet,
The Legend.TextStyle by default shows the values and the labels if present, and it alignes the "text" to the right. If you set the TextStyle to be Plain, like you would do if you would like to show the labels, the text is aligned to the left:
Chart1.Legend.TextStyle:=ltsPlain;
erzsebet
Post by erzsebet » Fri Aug 06, 2010 2:53 pm
Thank you, Yeray!! That was exactly what I needed to do to fix my legend text alignment problem! You and your entire team are awesome!
- erzsebet
