How to join different points with each
trimble
Post by trimble » Wed Jun 23, 2010 3:00 pm
I am using polar bar series. I have 100 points in alist and each point is changing its angle w.r.t time ,and I want to join each angle of the point at different time by a line and only different angle values for given point has to connect with a line not another point's angle value, So do u have any idea how to do it?
regrads
Trimble
Re: How to join different points with each
Post by Yeray » Mon Jun 28, 2010 2:16 pm
Hi Trimble,
I'm not sure to understand what are you exactly trying to obtain here. Could you please show the expected result in a picture?
Thanks in advance
trimble
Post by trimble » Tue Jun 29, 2010 9:36 am
Pls see the attached image, In this image I ahve one point name GPS3 on different angles and I want only these point to join via line not any other points. I hope u understand.
regrads
Trimble
Post by Yeray » Tue Jun 29, 2010 10:49 am
Hi Trimble,
If I understood well, you want the PolarBar series to show the line for some values and not in another ones.
I'm afraid you should hide all the lines and draw the desired lines manually. Here is an example:
        Steema.TeeChart.Styles.PolarBar polarbar1;
            polarbar1 = new Steema.TeeChart.Styles.PolarBar(tChart1.Chart);
            polarbar1.FillSampleValues();
            polarbar1.Pen.Visible = false;
            tChart1.BeforeDrawSeries += new Steema.TeeChart.PaintChartEventHandler(tChart1_BeforeDrawSeries);
            tChart1.Draw();
        void tChart1_BeforeDrawSeries(object sender, Steema.TeeChart.Drawing.Graphics3D g)
            tChart1.Graphics3D.Pen.Color = polarbar1.Pen.Color;
            tChart1.Graphics3D.Line(polarbar1.CalcXPos(5), polarbar1.CalcYPos(5), polarbar1.CircleXCenter, polarbar1.CircleYCenter);
trimble
Is TeeChart for .NET 2010 EVAL also supports 64 bit OS
Post by trimble » Wed Jul 28, 2010 2:21 pm
Is TeeChart for .NET 2010 EVAL also supports 64 bit os I am using win 7 64 bit , So is it possible to use the same elevation version for both 32 or 64 bit os or like TeeChart for .NET 2009 , U have different package for win 64 bit os.
regrads
trimble
Post by Narcís » Wed Jul 28, 2010 2:30 pm
Hello trimble,
No, it is the same as with TeeChart for .NET 2009. In x64 environments you can use x86 installers for evaluation.
trimble
Post by trimble » Wed Jul 28, 2010 3:32 pm
As I told in my pervious post I am using 2010 .net Eval with win 7 64 bit machine . when i tried to call Steema.Tchart .dll within my silver light application I got the following eror please see the attched screen shot. I think it not support 64 bit version. Or do u have any solution for it.
plz look at the attched screen shot
Post by Narcís » Thu Jul 29, 2010 10:06 am
Hi trimble,
For Silverlight projects you should not use TeeChart.dll you should use TeeChart.Sivlerlight.dll. Therefore namespace and class names are also a little bit different. Can you please confirm that you are using TeeChart.Silverlight.dll?
Also notice that in x64 environments you'll have to build Silverlight applications in v86 mode which forces the use of a 32-bit browser:
http://forums.silverlight.net/forums/p/ ... 61883.aspx
http://arstechnica.com/microsoft/news/2 ... 64-bit.ars
trimble
Post by trimble » Tue Aug 03, 2010 9:18 am
I am using TeeChart.Silverlight.dll it was only the the typing mistake before. I tried to compile the project as x86 project . It throws the exception at the
Line: 54
Error: Unhandled Error in Silverlight Application
Code: 2105
Category: InitializeError
Message: Failed to load pre-requisites for the application
U have two different distribution for the .Net 2009 Steema library before one for 32 bit and other for 64 bit , it works fine with my applicatin for .Net 3.5 , but now I am migrating to :net 4 and the elevation version of steema 2010 throwing this exception. So dont u have any package for 64 bit windows machine?
regrads
trimble
Post by Yeray » Wed Aug 04, 2010 11:31 am
Hi trimble,
Is the error reproducible creating a new simple application or only when trying to update an old one?
In the customer area you should find a 32 bits and a 64 bits dll for Win32 applications.
trimble
why these things are happening in Bar series
Post by trimble » Wed Aug 11, 2010 12:26 pm
Hello ,
I have created an application where I am using bar series to display my result . but I found strange thing while drawing the graph there is unwanted part is attached from one bar to another bar .I tried to figure it out but didnt suced . I am attching the pic where I have circled the unwanted peaks. plz have a look and tell me whatz wrong .
regrads
Trimble
Error image
Post by Yeray » Wed Aug 11, 2010 3:31 pm
Hi Trimble,
Could you please arrange and send us a simple example project we can run as-is to reproduce the problem here?
It seems that you may be setting a conflictive BarWidthPercent and CustomBarWidth.
trimble
How to acess ,add delete the legend items
Post by trimble » Fri Sep 17, 2010 1:56 pm
I am trying to modfied the legend programtically i.e I want to reomve some point from legend only but not from the chart . So do u have an idea how to do this? How I can add and reomve the elemnts from the legend .
regrads
Trimble
Post by Yeray » Mon Sep 20, 2010 7:24 am
Hi Trimble,
I'm afraid you can't add or remove items in the default legend. However, you could draw your own legend as in the example Christopher Ireland posted here.
trimble
Post by trimble » Tue Sep 21, 2010 5:10 pm
hi,
I cannot find TChart.Add.Control() option in teechat.silverlight .dll. So thats why I cannt create my own legend.
regrads
Trimble
