Lowest axis label disappears
ChartIt
Post by ChartIt » Mon Jul 26, 2010 9:09 pm
I have two custom axis as seen on the enclosed screen shot.
If the axis scale is set from -1 to 11 (as the first custom axis), everything is displayed OK.
If the axis scale is set from -2 to 11 (as the second custom axis), the lowest label disappears!
Here is the relevant code:
for i := 1 to 2 do
Chart1.Axes.Items[i+5].SetMinMax(frmGraphSettings.ViewScaleFrom, frmGraphSettings.ViewScaleTo);
Chart1.Axes.Items[i+5].Increment := (frmGraphSettings.ViewScaleTo - frmGraphSettings.ViewScaleFrom)/10;
Chart1.Axes.Items[i+5].RoundFirstLabel := False;
Do I do anything wrong, that causes the lowest label to disappear??
Chart axis.JPG (42.48 KiB) Viewed 8128 times
Re: Lowest axis label disappears
Post by Yeray » Tue Jul 27, 2010 3:36 pm
Hi ChartIt,
I've tried to reproduce it with the following code but couldn't:
uses Series;
var n, i: Integer;
  Chart1.Align:=alClient;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Chart1.MarginRight:=10;
  for n:=0 to 1 do
    Chart1.AddSeries(TFastLineSeries);
    Chart1[n].Add(Random*10);
    for i:=1 to 49 do
      Chart1[n].Add(Chart1[n].YValue[i-1]+Random-0.4);
    Chart1.CustomAxes.Add;
    Chart1[n].CustomVertAxis:=Chart1.CustomAxes[n];
    Chart1.CustomAxes[n].OtherSide:=true;
    Chart1.CustomAxes[n].RoundFirstLabel:=false;
    Chart1.CustomAxes[n].Axis.Visible:=false;
  Chart1.CustomAxes[0].Increment:=1.2;
  Chart1.CustomAxes[1].Increment:=1.3;
  Chart1.CustomAxes[0].SetMinMax(-1,11);
  Chart1.CustomAxes[1].SetMinMax(-2,11);
  Chart1.CustomAxes[1].LabelsFont.Color:=clRed;
  Chart1.CustomAxes[1].PositionUnits:=muPixels;
  Chart1.CustomAxes[1].PositionPercent:=Chart1.CustomAxes[1].PositionPercent-30;
Could you please tell us wha exact TeeChart version and IDE are you using?
ChartIt
Post by ChartIt » Tue Jul 27, 2010 8:47 pm
Sorry for the missing information.
I use TChart Pro v7.08 with Delphi 2006 on Windows XP Professional SP3.
ChartIt
Post by ChartIt » Tue Jul 27, 2010 8:58 pm
I get the same bad result when trying your code.
Chart axis.JPG (141.84 KiB) Viewed 8056 times
Post by Yeray » Thu Jul 29, 2010 8:54 am
Hi ChartIt,
I've reproduced the issue in a system like yours and I can confirm that the latest TeeChart VCL v2010 works as in the picture I showed you before.
You can try it if you want: http://www.steema.com/evaluation/vcl
In v7 I've also seen that playing with the MinimumOffset you could work around this:
Chart1.CustomAxes[1].MinimumOffset:=1;
ChartIt
Post by ChartIt » Sun Sep 12, 2010 8:27 am
Hi again :)
I upgraded to v2010 and the label disappearing problem seemed to be solved.
I then upgraded further to the "non-stable" upgrade to solve a couple of other issues.
It now seems like the label disappearing problem has been reintroduced (see screen shot).
What's going on??
Lower label.JPG (69.77 KiB) Viewed 7984 times
Post by Yeray » Tue Sep 14, 2010 11:08 am
Hi ChartIt,
First, I've ran the project I proposed above and noticed nothing irregular.
Then I saw in your picture that you've changed the axes minimum and maximum, and , after trying the same than you, I could reproduce the problem.
uses Series;
var n: Integer;
  Chart1.MarginLeft:=20;
  for n:=0 to 4 do
    Chart1[n].FillSampleValues();
    with Chart1.CustomAxes[n] do
      Ticks.Visible:=false;
      PositionPercent:=-n*30;
      LabelsFont.Color:=Chart1[n].Color;
      if ((n = 0) or (n = 1) or (n = 2)) then
        SetMinMax(-24, 216)
      else if (n = 3) then
        SetMinMax(-0.2, 1.8)
      else if (n = 4) then
        SetMinMax(-0.3, 2.7);
      Increment:=(Maximum - Minimum) / 10;
      //MinimumOffset:=1;  //workaround
So it seems to be reproducible in very particular cases, and still the MinimumOffset property seems to solve the problem.
Anyway, I've added it to the defect list to be revised fur future releases (TV52015150).
