I want Bottom axes like this picture.
And this my setting:
logarithmic is true, Log base is 10, and inverted is true.
But I get this chart.
Is there any way to change the width?
Please tell me.
logarithmic axes problem
Re: logarithmic axes problem
Hi Richard,
I'm afraid the only solution is that you manually add desired labels to data points when populating series or manually parse labels in the GetAxisLabel event as shown here:
for (int i = 0; i < 100; i++)
line1.Add(i * i, Convert.ToString(Math.Pow(10, i) / 1000));
tChart1.Axes.Bottom.Inverted = true;
tChart1.GetAxisLabel += new Steema.TeeChart.GetAxisLabelEventHandler(tChart1_GetAxisLabel);
void tChart1_GetAxisLabel(object sender, Steema.TeeChart.GetAxisLabelEventArgs e)
//if (sender.Equals(tChart1.Axes.Bottom))
// e.LabelText = Convert.ToString(Math.Pow(10, e.ValueIndex) / 1000);
Hi, Narcís
Thanks your help.
The problem has been solved after I used older version.
Thanks your help.
